- Aero Spoiler End Caps
- WTB: Stock LNF struts or springs
- Wanted: SS Turbo Wheels
- WTB: LNF 3" catback exhaust
- WTB: Black SS front bumper spoiler lip
- WTB: LSJ Bypass Valve Actuator
- I think I want Coilovers
- ZZP girdled block
- WTB mpx muffler delete section
- SS Sedan Rear Bumper, Sedan Door Panels, Antenna, Headlights
- Headlight adjuster, philips head
- FE5 struts and shocks (pref. with lowered springs)
- WTB: Cobalt SS/TC (LNF) OEM Wheels
- WTB Bolt on Turbo
- 2.2 or LSJ
- WTB K&N Intake
- Used LNF springs in Cent. FL area
- WTB or Trade SS/TC seats for my Corbeaus
- WTB boost gauge
- Wanted: SS lower grille
- Looking for TVS
- Looking for parts to buy
- Wtb stage kit
- Wtb fuse box terminal cap
- WTB 1 SS TC wheel
- WTB: ZFR of K04r
- 60# injector
- Bcm lnf
- WTB oem BPV and bpv solenoid for lnf
- Wanted stock flywheel
- WTB stock LSJ boost gauge
- WTB: Spec 4 stage clutch
- WTB: #60lb or #80lb injectors
- Wtb stock pioneer ss subwoofer
- stock lsj f35 axel
- Wtb lnf parts - 02, intake, af intercepter hpt etc
- Stock ss wheel turbo
- WTB: Adjustable clutch rod.
- Wtb: modern performance 3in muffler delete section
- Wanted: LNF Meth plate
- WTB: Stock LSJ Gauge
- Wtb
- WANTED-cobalt ls front bumper lip (2006)
- Wanted: Cobalt SS Front Lower Lip - Mine ripped off driving through a blizzard...
- WTB Black SS front bumper/passenger fender
- Wtb: Zfr
- WTB: Saturn Vue Final Drive
- Wanted: Cobalt SS Lower front bumper Grille
- Hptuners
- wtb Tvs
- wtb header
- WTB aftermarket intercooler, big turbo
- 80lb injectors
- WTB: upgraded clutch
- WTB: stock LNF O2 housing.
- L61 to LSJ serpentine belt and components
- Looking for balt in Ohio
- WTB LAP (2.2L) Motor
- Looking for a pulley puller tool
- I think i need an engine bay fuse box. prices?
- Wanted:charge pipes- no bov, aftermarket intercooler, and a zzp radiator for LNF
- Looking for k&n intake
- Looking for lsj stage 2 parts Ontario Canada
- WTB ZZP UFPL Cam
- WTB: Working OEM boost gauge
- Wanted: ZFR 7163
- WTb: TVS
- WTB: Fuel pressure regulator for LSJ
- rotated trans, sts, RETRO'S, zzp hi voltage coil packs,
- WTB upper LNF grill insert & LSJ rear lip
- Iso TVS
- Want to buy HPTuners
- zzp manifold
- Wanted: 07 2.2 Head
- WTB: Upper LNF Grille
- Looking for an 02 fuel rail
- WTB K&n SRI for LNF
- Aeroforce Interceptor
- Forge BPV
- WTB coupe trunk
- WTB: #80 injectors
- Wtb: bracket for arm rest and cup holder
- WTB/Where to buy all OEM 'intercooling' lines LSJ
- RPD A Pillar trim
- front bumper, side skirts, rear bumper for SS.
- Wtb BPV solenoid, Vacuum tank
- Wanted: Part # 22720657
- M62 kit
- WTB: ZZP LNF ported head and cam combo
- WTB: K&n intake/injen upper CP for LNF
- Dual pass and stage 2 belt
- Transmission wanted
- 09 lnf ecu
- WTB: 60lbs injectors ev1
- 80 lbs injectors
- WANTED. YYz springs or pedders
- WTB: LSJ Throttle Body
- LTB Lower/Upper Charge Pipes, BOV
- WTB: LNF oem intake box
- Lsj goodies
- ZFR or big turbo upgrade, ss sc wing
- Headlights
- interior ss emblem
- needs emblems
- WANTED: Upper grill and front fenders
- WTB Front and Back Bumper and Hood
- WTB Stock Pioneer Sub Connector
- WTB Pistons for 2.4
- WTB: lower intake manifold brace
- NEED - SS/TC rear axle
- Brembo brakes
- Black on Black OEM Seat Covers
- Looking to Trade
- ZZP lsj intake
- WTB Stock LSJ Tensioner Pulley
- WTB F23 Shifter box
- WTB: LDK or LHU in Canada
- WTB M62 Blower
- WTB: MSD Ecotec Distributor
- WTB: OEM Coupe (Non-SS) A Pillar
- Bolt on turbo
- WTB: Solstice LNF Crank Pulley
- WTB: LNF or LSJ car for swap or 2.2L L61 motor
- WTB many lsj bolt on parts.
- Coilover parts
- Wtb ss/sc stock air box
- Wtb tvs supercharger
- Wtb LNF Injector seal tool
- WTB Rear left capiler ( drivers side ) 09 SS/TC
- WTB SS TC oem shift knob in perfect shape
- Muffler
- WTB: LSJ SS wheels
- WTB: high rise spoiler end caps.
- Iso of valve cover bolts
- WTB: SS/TC K&N Intake or Drop in Filter
- *WANTED* Silver HVAC with all bulbs good
- Wanted: Powder coated LSJ Valvecover
- Wanted - LSJ Rear O2 Sensor (Downpipe)
- Wanted: 4.05 LSD Trans
- Anyone near Baton Rouge have some stock springs?
- Wtb lnf pcm
- looking for harrop tvs charger used if possible
- LNF Catback Exhaust
- Wanted: 3.0" ZZP pulley and #42 injectors
- Wtb stage 3 kit for lsj cobalt along with other bolt ins.
- Wtb: Hp tuners cable
- Dual steering gauge pillar
- WTB: Corsa Touring catback
- Lnf short shifter
- WTB: SS LNF Seats
- WANTED: 07 LE5 Engine Harness
- Wanted:supercharger bypass solenoid
- Wanted:a lot of LNF upgrade parts
- WTB Hood and pass Headlight
- LED Coupe tailights
- Anybody in Indiana? Or nwi?
- Lightweight Track Wheels - 18" diameter, 8-9" wide
- After market lower charge pipe and Intercooler
- Wanted: 3rd Brake Light
- WTB: Stock lnf upper charge pipe
- WANTED: LE5 or LAP engine harness
- Wtb 2.8 pulley 4 bolt
- Looking for a turbo zfr, k04 r or +
- Wanted- Factory LNF Boost Gauge
- LSJ Rear Passenger Caliper
- WTB G85 LSJ transmission
- LSJ IC pump
- Wanted aftermarket intake. Need ASAP
- WTB OEM TC wheel
- Head Studs
- Wanted: Stock Taillights
- Wtb
- Complete LSJ
- 15in 4 lug steelies (4x100)
- Anyone selling a catback?
- stock airbox 2006 SS SC
- WANTED: aftermarket hood
- WTB: LNF shocks/struts and springs
- starter
- LNF Aeroforce dual gauges and zzp triple pod
- WTB LNF Airbox
- Turbo for LSJ turbo swap
- OEM: Springs, Cold side, IC, and/or clock spring
- WTB: LNF passenger side axle and control arm
- Looking for LSJ turbo swap parts
- WTB Drivers Seat LS Coupe
- ISO ls4 tb adapter plate bolts
- WTB: Single Wheel
- WTB F23 transmission
- WTB: OEM Stick Shifter Pattern Insert
- WTB: LNF K&N Intake
- WTB: F23 Shifter linkage box
- Side exit exhaust for lnf
- WTB: Single SS/TC Wheel
- Wanted: SS Sub or similar Subwoofer
- Wanted: SS T/C Wheels
- WTB lowering springs for 2007 Cobalt SS/SC
- WTB Parking Brake Adjuster/Cable
- looking for coilovers
- WTT: My ZZP upper for any CP with BOV/flange
- LSJ stage 3 parts
- HPT, Catless DP, Corner Markers, Wideband
- WTB: SS Shifter and LNF Shift Bracket
- XXX powell rear sway bar or trade for Hardcore rear sway bar
- Forge Divertor Valve and stuff
- WANTED - Smoothflow pulley hub removal plate
- trade devils own meth kit for brembos
- Trifecta
- WTB: SS Rims
- WTB: Supertech valve springs for lnf
- LZM BSD kit
- LSJ laminova cores + washers
- WTB cobalt ss high rise spoiler
- Wanted single or pair TC rims
- LE5 2.4 intake cam
- strut bolts
- WTB HP Tuners Pro
- Wanted: forged bpv/diverter valve
- WANTED: broken k04 turbo
- lsj dipstick tube
- Need PCM for a 2006 cobalt ss lsj 2.0
- Wanted: SS S/C Polished wheels, have SS N/A wheels with new tires to trade
- Wtb reverse taillights, projector headlights, triple gauge pod
- WTB : LNF mechanical boost gauge psi
- jannetty side exit exhaust
- stock lsj air intake
- trade seats...i have tc seats!!!
- WANTED: 3" pulley + hub Gms2 or Gms3
- wanted; intercooler and pipes
- Drag radials
- Wtb '09-'10 ss
- Need a new coupler/rubber piece for an injen intake (also other wants but not needs)
- 05-06 lsj dipstick
- Lowering springs
- Wanted single SS/TC Wheel
- Wanted ZZP 2.6" Pulley
- WTB: Complete Dash
- WTB: rear spring / springs
- 42# injectors for lsj cobalt (looking for oem)
- Wanted LSJ Factory air intake
- wtb single cluster pod or triple gauge pod
- WTB: Stock Shift Knob Silver Top Piece
- hpt and 3bars
- WTB: Headlight Assembly
- WTB 08 2.4 LE5 parts
- WTB Laser Blue Driver's ext. door handle
- Lnf pcm
- 08-10 LNF OEM Lower Charge Pipe
- Need rear seatbelt
