Removing badge goo?
Removing badge goo?
I de-badged my Cobalt about a month and a half ago. Everything came off pretty easily and cleaned up nicely, except for the bow-tie on the trunk. I've had a good chunk of the goo stuck on there since then. It's survived heavy soaping, goo-gone, WD40 and a power-ball waxing.
Any suggestions as to how I get it off?
Fingernail. Seriously. And I mean that as in for realz, not the smart a$$ version of seriously. Pull it in someplace warm, use a heat gun if you have one and rub it off using a combo of your finger and fingernail.
I de-badged last week in the cold, well not-so-cold MI air. Blow dryers help A LOT. So does alcohol and an ice scraper.
I held the blow dryer on the black **** and scraped it. It took about 5-7 min. Most of the black **** didn't stick to the emblem, so I had to scrape little-by-little. Just scrape and alk. Repeat. Wash & wax when you're done.
I had to rub mine off with the skin of my finger. Burned like hell but it worked perfectly. I also had to do that when I removed the door molding on my old LT sedan. Talk about pain. Glue remover didn't really help with the heavy foam.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Cptnslo
Sep 24, 2015 09:32 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
