North Central ND, SD, MN, and WI
Local Part out!
Old Jul 27, 2012 | 05:02 PM
Ryze's Avatar
Local Part out!
As some of you know from my facebook, my car fell off a trailer and they decided to total the car out. I bought it back, because frankly the damage was so minimal that I can turn it to a stock car and make more money off of it.
I'm looking to part out all the go fast parts from it. in exchange for stock parts.
HTV TVS 1320 with atleast a 2.9 and a 2.7 pulley, may even have a stock pully laying around but need to find it first. $1250 plus your stock M62.
Built 2.1L Ecotec shortblock about 4k miles on it since last year when I put it in..runs great.
this includes. $2200
2.4L Gen 2 block assembly
2.0L LSJ crank
2.0L LSJ Rods cyrotreated
Custom 9.5:1CR 88mm bore Wiseco pistons, with coatings
Level Zero Motorsports Balance shaft Delete kit.
I have a receipt for all the work done @ Modern Automotive Performance
ARP head stud kit
Next up is my PnP head assembly $1200
Stage 4 Port and Polished LSJ head
Combustion chambers matched to 88mm bore
stock valves
SuperTech Valve springs with titanium Retainers.
This does not come with cams, valve cover, rocker followers, timing chain or gears, or oil pan..I need these items for the stock engine I have laying around..
IF someone was interested in a straight trade engine for engine we can work something out, and I would be more than happy to install both engines for a minimal fee. You can even hear my engine run still if your interested.
60 lb injectors $100 with trade for stock injectors with harness
Custom Return style fuel system $300, Includes fuel rail, braided return hose, Aeromotive AFPR, and walbro intank pump. Would need stock fuel rail and pump.
Meth injection kit $100.
MSR 068 Wheels with 235/40/17 Dunlop Direzza tires almost new
$600 $500 with stock wheels and tires
Progress lowering springs, and rear sway bar.. Make offer.
Text or call me 763-234 eight six seven zero if you are interested..or email me. Car is located in fridley if anyone wants to come look at it.
Ryan
Oct 20, 2015 09:56 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
dieGone
Oct 1, 2015 06:27 PM
metroplex
Sep 27, 2015 07:48 AM
