Meth Fluid Help
Old Feb 15, 2009 | 07:17 PM
mexi_loco's Avatar
Meth Fluid Help
Hey, for anyone that uses meth down in texas, what kind of windshield washer fluid do you use? I know it's best to use one that's at least -20*, but I don't believe they sell anything less than 0*. So if you use 0*, do you know what ration of meth/water is in the 0* mixture. I'm curious about the last question so I know how much HEET to use to make it a 50/50 mix.
Old Feb 15, 2009 | 07:20 PM
RedEcotecSS's Avatar
Go to Advance Auto Parts.. Here in NC they have -20* don't see why they wouldn't in TX. Also.. 1 bottle of -20* and 2 bottles of the yellow HEET bottles will make about a 50/50 mix.
Old Feb 15, 2009 | 07:21 PM
widowedeight's Avatar
cause it is texas.... how often do you think it gets to -20* lol
Old Feb 15, 2009 | 07:22 PM
How often do you think it gets to -20* in NC? Never... It's rarely below 30* here.
Old Feb 15, 2009 | 07:25 PM
mexi_loco's Avatar
I've gone to AAP, and the only sell +20*. I wouldn't be making the OP if I hadn't done my research first, lol.
Old Feb 15, 2009 | 07:29 PM
Hmm. Did you ask them if they could get you any -20 in? haha.
more often than texas.... which would be why they prob don't sell it there also another reason that they would sell it in NC is cause it wouln't be to bad of a drive if you wanted to go somewhere north where it would be cold as **** (8 hrs?) but for him it would be a 12 hr drive just to get to somewhere chilly.... just saying
Old Feb 15, 2009 | 07:30 PM
never thought of that.. haha i guess your right.
Old Feb 15, 2009 | 08:57 PM
mexi_loco's Avatar
so any texas guys have any .02 cents about this?
Old Feb 15, 2009 | 09:21 PM
will20four's Avatar
from AIS website
Old Feb 16, 2009 | 10:42 AM
mexi_loco's Avatar
I've already seen that article. That's what gave me the idea to combine heet with windshield washer fluid But, the problem is still the fact that I can't find any fluid that's rated at -20*. So, what I'm trying to figure out is either where to get -20 down here in texas, or what everyone uses down and what the ratio of meth to water so I can see how much heet to add to that.
Old Feb 16, 2009 | 11:54 AM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Do you have any circle dirt tracks nearby? This is a great place to get pure methanol cheap. They run the midget cars on this stuff and will generally sell it to you for about $5.00 a gallon. Mix that 50/50 and its only costing $2.50 per gallon.
For those that are using -20 degree below zero windshield washer fluid. You need to add four bottles of Heet to raise it up to that 50/50 range.
-20 Windshield washer fluid is typically 30-35% methanol (depending on the brand)
1 gallon contains 128 oz
30-35% methanol is 38-45 oz
Remaining water/fluid is 90-83 oz
You need approximately 4 bottles of HEET (12 oz each x 4 bottles=48 oz) to bring the methanol volume up to match that of the water to get approximatly 50/50 water methanol.
Old Feb 16, 2009 | 08:59 PM
mexi_loco's Avatar
Unfortunately, I live inside the city, so there's dirt tracks around here that I know of. That's why the windshield washer fluid + heet is my best option.
*0ff topic* - just bought your stage I kit and I'm looking hella foward to installing it
Anyways, do you by any chance know the ration of meth/water in 0* fluid? Or how about +20, as that's the most common type of fluid down here.
Old Feb 18, 2009 | 01:58 PM
AIS's Avatar
AIS
Go to home depot and buy denature alcohol then. its in the paint department. mix that 50/50 with distilled water. Denatured alcohol is generally 85% ethanol with 15% methanol. Works just as good.
Old Feb 18, 2009 | 02:42 PM
SSSCEnthusiast's Avatar
I just run straight denatured alcohol.
Old Feb 18, 2009 | 02:47 PM
QuikSilverSS's Avatar
Buy a gallon of methanol or methyl hydrate from a hardware store in the paint section, mix 50/50 with distilled water...there you go, you have your meth fluid. Easier than running windsheild washer, because it contains no detergant like washer fluid.
Old Feb 18, 2009 | 03:07 PM
Kage's Avatar
Guess I could key in here. The guy at the north side meet I took you to with the Blue SRT4 run pure or mixed but starts with pure meth. If you want I can check with him and see where he gets it but I can say it will be on the far north side of Houston.
Old Feb 18, 2009 | 07:05 PM
AIS's Avatar
AIS
There you go. I prefer running it pure too.
Old Feb 18, 2009 | 07:09 PM
will20four's Avatar
no problems running that straight?
better to run some water mixed?
run lean/rich with just denatured alcohol?
Old Feb 18, 2009 | 08:05 PM
AIS's Avatar
AIS
Why is it better to run some water?
Old Feb 18, 2009 | 09:12 PM
mexi_loco's Avatar
you caught my interest here. I think it's like 12 bucks for a gallon. Is this straight meth (i know methyl hydrate is another name for methanol), or are there other components in the stuff in it too?
Old Feb 18, 2009 | 11:37 PM
will20four's Avatar
no, i was ASKING if its better to run it with some water mixed or just straight.
Old Feb 18, 2009 | 11:48 PM
Depends on if you're looking for power or cooling.
With straight water injection, you're lowering intake temps.
With a 50/50 Mix you're lowering intake temps and probably knocking your timing up a degree.
With Straight Denatured I was able to bump my timing up about 3*
Old Feb 19, 2009 | 12:08 AM
OnebadaSS_SC's Avatar
Depends on where in TX you are...There is a huge VP distributer here in texas and you can get 5 gallons of Meth for $42. So if you mix it 50/50, you get 10 gal of mix.
Old Feb 20, 2009 | 10:27 PM
mexi_loco's Avatar
I was just thinking, and someone please correct me if I'm wrong cause I'm so new at this. Heet is pure meth for your gas lines, right? That's the whole reason why you would add it to washer fluid (to up the meth content). What if I just used 8 bottles of heet and mixed that with distilled water? Wouldn't that be fine to run as a 50/50 mix of meth/water?
