Meth Fluid Help
Old Feb 20, 2009 | 10:29 PM
RedEcotecSS's Avatar
Originally Posted by mexi_loco
I was just thinking, and someone please correct me if I'm wrong cause I'm so new at this. Heet is pure meth for your gas lines, right? That's the whole reason why you would add it to washer fluid (to up the meth content). What if I just used 8 bottles of heet and mixed that with distilled water? Wouldn't that be fine to run as a 50/50 mix of meth/water?
If you don't have a direct answer by like Money then call AIS directly. Rodney will help you out man.
Old Feb 20, 2009 | 10:31 PM
mexi_loco's Avatar
can't wait til then. Everything's gonna get installed tomorrow. So unless I get an answer by then, I'll be running the washer fluid.
Old Feb 20, 2009 | 10:33 PM
When I first installed my AIS kit, I could only find 0* washer fluid and I added like 5 bottles of HEET and it seemed to work nicely.
Old Feb 20, 2009 | 10:37 PM
mexi_loco's Avatar
Do you still use this method? Or have you decided to use something else? I guess my concern now with using washer fluid is that it might have other stuff in there that might f*ck my engine over in the long haul.
Old Feb 23, 2009 | 05:56 PM
BlkWdoSS's Avatar
why not just go to baytown raceway park and get meth straight from them?
if you are going to GM lonestar bash, the Texas Motorplex has it, thats where I get mine and then pick up a few gallons of distilled water for a couple bucks from walmart and create my own meth lab at home with diff % to play around with
Old Feb 24, 2009 | 09:36 AM
mexi_loco's Avatar
The reason I'm not looking to go to any tracks to buy meth is cause I'm trying to look for a convenient and cost effective solution. So far, the denatured alcohol idea and using heet + water are the best ideas. Right now, I'm going to experiment with heet + water and see how that goes. I figure if it's safe enough to drop into the fuel tank, it's safe enough to spray into the engine. I'll let everyone know how it goes.
Old Feb 24, 2009 | 05:46 PM
BlkWdoSS's Avatar
o ok, well i was wondering about that, the track is convenient to me, I live 20 mins from there and we keep enough fuels setting around my shop that I can store a lot of Meth for times when I cant get to the track.
Old Feb 25, 2009 | 11:36 AM
will20four's Avatar
how did the install go?
what was the final solution to the mix you made?
Old Feb 25, 2009 | 12:03 PM
SSSCEnthusiast's Avatar
Everyone's talking about " Im gonna buy xxx bottles of HEET and add it to washer fluid"... Heet is 2.50 a bottle, and windshield washer is about 2.50 a gallon, WHY take this route, when you could get a gallon of Denatured for 15 dollars at any lowes in the country?
Old Feb 25, 2009 | 12:33 PM
mexi_loco's Avatar
Still having issues with bleeding the system. I stripped a wire on accident of its connector, so I have to krimp another one on there. Once I bleed it though, I'm going to tap it into my intake.
I have decided to run a 50/50, half Heet and half water.
The reason I decided to use pure heet as oppose to denatured alchol is because of the ingredients. Denatured alcohol is ethanol with a little mehtanol to make it poisonous to consume. I prefer to use pure methonal, but again, that's just my opinion/preferance, plus I don't feel comfortable using washer fluid anymore because of other detergents that could be in them. I don't read labels carefully enough to pick a good washer fluid.
Yeah, heet might be more expensive in the long run, but I don't go WOT unless I'm playing around in "mexico", or boost more than 5psi when dd, so this will actually end up being a pretty cheap solution.
Old Feb 25, 2009 | 12:44 PM
  #36
will20four's Avatar
stupid question but what do you have to bleed? i never heard about having to bleed anything for the install?
Old Feb 25, 2009 | 03:17 PM
  #37
mexi_loco's Avatar
have to bleed the air out of the system. Don't want to spray air into the engine.
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
