Meth Fluid Help
I was just thinking, and someone please correct me if I'm wrong cause I'm so new at this. Heet is pure meth for your gas lines, right? That's the whole reason why you would add it to washer fluid (to up the meth content). What if I just used 8 bottles of heet and mixed that with distilled water? Wouldn't that be fine to run as a 50/50 mix of meth/water?
Do you still use this method? Or have you decided to use something else? I guess my concern now with using washer fluid is that it might have other stuff in there that might f*ck my engine over in the long haul.
why not just go to baytown raceway park and get meth straight from them?
if you are going to GM lonestar bash, the Texas Motorplex has it, thats where I get mine and then pick up a few gallons of distilled water for a couple bucks from walmart and create my own meth lab at home with diff % to play around with
The reason I'm not looking to go to any tracks to buy meth is cause I'm trying to look for a convenient and cost effective solution. So far, the denatured alcohol idea and using heet + water are the best ideas. Right now, I'm going to experiment with heet + water and see how that goes. I figure if it's safe enough to drop into the fuel tank, it's safe enough to spray into the engine. I'll let everyone know how it goes.
o ok, well i was wondering about that, the track is convenient to me, I live 20 mins from there and we keep enough fuels setting around my shop that I can store a lot of Meth for times when I cant get to the track.
Everyone's talking about " Im gonna buy xxx bottles of HEET and add it to washer fluid"... Heet is 2.50 a bottle, and windshield washer is about 2.50 a gallon, WHY take this route, when you could get a gallon of Denatured for 15 dollars at any lowes in the country?
I have decided to run a 50/50, half Heet and half water.
Yeah, heet might be more expensive in the long run, but I don't go WOT unless I'm playing around in "mexico", or boost more than 5psi when dd, so this will actually end up being a pretty cheap solution.
