South Pacific CA, NV, and HI
SS wing help
Old Jul 23, 2010 | 07:34 PM
Ayanez's Avatar
SS wing help
Hey whats up just here need help taking of my oem wing some how that **** wont come off idk i took of the screws maybe there mor to it??
gonna put an ss wing
Old Jul 23, 2010 | 07:49 PM
SS-Performance-RS's Avatar
The reason it doesnt just pull right off is because there is some realy good double sided tape on the mounting area. Heat it up with a blow dryer or heat gun and itll release
Old Jul 23, 2010 | 07:57 PM
Ayanez's Avatar
would i have to put some of that double tape on the new one as well?
Old Jul 23, 2010 | 07:59 PM
SilverSS_TNR's Avatar
sorry but its not just tape, its some thick ass globs of glue, heat it up with a blow dryer, and then take some fishing line and cut threw it, it takes a while but it will eventually off, and then take WD-40 to get the rest off the **** off
Old Jul 23, 2010 | 08:10 PM
Most the time the new ones come with it
The glue is from the adhesive thats part of the tape. When you heat it up it gets like that. So you sir are wrong.
Old Jul 23, 2010 | 10:22 PM
you=fail, didnt say it wasnt tape, did I? negative, i simply said its more than just tape, when someone says dbl sided tape, thin tape with sticky on both sides comes to mind, not that **** they put on there, so id say its more than just dbl sided tape
Old Jul 24, 2010 | 02:22 PM
Thats the thing mr failure. It is all part of the tape the extra sticky glue it part of any double sided tape so by you saying it was an additive like a 2nd piece made you sound like fail.
Old Jul 26, 2010 | 07:06 PM
Ayanez's Avatar
thanks for all the info i got it on this weekend and i like how it looks...
heres a picture...
Old Jul 30, 2010 | 06:25 PM
redhot09cobaltss's Avatar
Did you have the lower wing in the first place? Does anyone know if the holes are the same for the lower wing and the high SS wing? I want to change my wing but don't want to fill holes and paint and make new holes.
Thanks
Old Jul 30, 2010 | 06:45 PM
Thanks
They are the same holes
Cptnslo
Sep 24, 2015 09:32 AM
dieGone
Sep 23, 2015 10:20 AM
chevytech329
May 20, 2015 11:47 PM
DomesticDemonSS
Feb 27, 2011 11:00 PM
DruZ24
Sep 13, 2005 05:05 PM
