Fs Audiobahn Amp A12001dt
Audiobahn Mono Block Amp A12001DT $150.00
Still have the original box. And Instructions, Remote Bass ***, Also throwing in a set of Lightning Audio: Zero Noise Audio Cables
Only 6 months old had it for my 15" Treo Sub but needed more power
# Class D Circuitry
# Multi Standed Power Supply Toroids
# Double Sided Glass Epoxy Circuit Board
# THD : 0.05%
# S/N Ratio > 100dB
# Frequency Response : 10Hz - 40Hz (+ / - 1dB)
# Remote Bass Control with Blue Backlight Knobs
# Variable 18dB Low Pass Crossover : 50Hz- 250Hz
# Variable Bass boost : 0 - 18dB
# Variable Bass boost Frequency : 40Hz - 100Hz
# Subsonic Filter :20Hz - 50Hz
# Variable Phase Control : 0' - 180'
# Large Display Volt Meter with Blue Illumination
# Throughput RCA Connections
# 4-way Protection Circuitry : Thermal, Short Circuit,
# Overload, and DC Offset
# Dual Cooling Fans
# Cobalt Blue Illumination
# Chrome Flame Fan Grille
# High Gloss Chrome Plated Finish
# 4 Ohms Mono : 400 x 1
# 2 Ohms Mono : 750 x 1
# 1 Ohms Mono : 1200 x 1
# Dimension(H x W x D) : 2 1/2" x 11 15/16" x 14 1/2"
# Class D Circuitry
# THD : 0.05%
# S/N Ratio > 100dB
# Dual Cooling Fans
it would be rediclous for you but im not looking to spend more than 150 i only have 1 12" cvr dont need this much power but i figured i would check to see if i could get it or not.
