FS MTX monoblock amp
For sale is a slightly used MTX MONOBLOCK AMP MODEL TA2301
Thunder TA Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 150 watts x 1 chan.
2 ohms: 300 watts x 1 chan.
Max power output: 300 watts x 1 chan.
MOSFET power supply
Wired remote bass level control included
Thermal and short LED indicators
Tuned Bass EQ (0-12 dB bass boost at 40 Hz)
Adaptive Class D Technology: With MTX innovative approach, the amplifier’s switching energy is constantly changing and is moved away from FM radio frequency ranges as the amplifier’s load and output increases.
Thermal and short protection
StreetWires Connectors
Xtant Technologies Cooling (XTC) thermal-regulated, turbo-charged intercooler
Variable low-pass filter (at 80 or 120 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Dimensions: 12-11/16"L x 9-5/8"W x 2-1/2"H
SPECS
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 150 watts x 1 channel
RMS Power (2 ohms) 300 watts x 1 channel
RMS Power (1 ohm) Not Stable
Bridged RMS Power N/A
Peak Power Output N/A
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power .5%
Speaker Level Inputs No
Preamp Outputs Yes - 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 80
Subsonic Filter N/A
Signal-to-Noise Ratio 73 dB
Channel Separation N/A
Bass Boost 0 - 12 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
$100 OBO
RMS Power Rating:
MOSFET power supply
SPECS
Amplifier Class D
Subsonic Filter N/A
Fan Cooled Yes
Fuse Rating 20A x 2
$100 OBO
like what you had to say had nothing to do with selling my mtx amp, its like you tried to find something to nit pick about to remain the rebel you are.
