For Sale Xbox 360
Old Oct 12, 2009 | 10:20 PM
SlowBalt_06's Avatar
Xbox 360
Ok I bought an xbox off eBay when I got it it came broke .. Sent it back.. Got it back broke 3 red rings I'm not gonna deal with it anymore it's a arcade with av cables and power brick 60 shipped
Old Oct 12, 2009 | 10:26 PM
weskimo's Avatar
just send it to microsoft. they should fix it for free.. they put a extra 3 year warrenty for the red ring of death ak 3 red lights
Old Oct 12, 2009 | 10:28 PM
Im not gonna deal with it I went and bought a new one
Old Oct 13, 2009 | 06:26 AM
-MD- HHR's Avatar
Is the warranty seal intact?
Old Oct 13, 2009 | 06:33 AM
Doubt it
Old Nov 9, 2009 | 10:27 AM
LamboW9's Avatar
the RROD's are easy to fix, i bought one on here from sum1 and fixed it and it works great. If you fix the console before you sell it you can get more cash for it rather than selling it for minimal money. If your mechanically inclined i recommend fixing it. Follow case removal procedures found easily online. Clean the heat sinks of all the dust, remove X-clamps, clean gpu and cpu and apply arctic silver 5 thermal compound an reinstall heat sinks and X-clamps and enjoy your working Xbox
Old Nov 9, 2009 | 10:41 AM
WickedSS2005's Avatar
Hmmm
Old Nov 9, 2009 | 11:52 AM
mcz34man's Avatar
if you want it to work right and not have to keep fixin do not put the xclamp on again get the nylon washers and the screws and tighten the heat sinks to the board. when you reheat all you are doing is resolder the bad connection points on the gpu or cpu depending on error code lights
Old Nov 9, 2009 | 11:56 AM
1BADSS/SC's Avatar
Originally Posted by mcz34man
if you want it to work right and not have to keep fixin do not put the xclamp on again get the nylon washers and the screws and tighten the heat sinks to the board. When you reheat all you are doing is resolder the bad connection points on the gpu or cpu depending on error code lights
exactly.
Old Nov 9, 2009 | 01:21 PM
LamboW9's Avatar
yea, you need to order the proper screws and washers. the heat sinks are dependent on a certain amount of pressure to be on top of the cpu and gpu so if there is no connection then you will get the red rings, if there is too much pressure then you will get the red rings. i fussed with the screws and washers and had mixed results, then i put back on the factory X-Clamp and it worked and has worked great.
if you don't wanna deal with the screws you can always clean everything as stated before, and resinstall the factory X-clamps and get a set of talismoon fans (25$) they replace stock fans and increase cooling which heat is the reason its red rings anyway. you should also try to keep a good airflow around the xbox and in a cooler temperature and you shouldn't have any problems then.
riceburner
Sep 27, 2015 11:10 PM
