Wanted Xbox 360 with Red Ring of Death
Old Jul 22, 2010 | 12:44 AM
silver187666's Avatar
letting it run while the red ring is on
Old Jul 22, 2010 | 12:45 AM
SC cobaltss15's Avatar
I am not... i just dont get what you are saying... I mean the towel trick and penny ways are liike kind of dumb... I mean i guess i do overheat it.. but after that there fine?
oh yea then i do over heat it, you made it sound like i really bad thing.. but i have had mine and worked fine for awhile?
Last edited by SC cobaltss15; Jul 22, 2010 at 12:45 AM. Reason: Automerged Doublepost
Old Jul 22, 2010 | 12:50 AM
over heating it only works for so long then they **** up over heating is aslways bad. if your doing this to "donate to the less fortunate" you would of red up more on this, like the best wa to fix them for longer life.
when you over heat it it doent fix the crapy clay heat sins that cause the problem in the first place, after you over heat it it leads to more rrs that arent as easy to fix
ramrod1337's Avatar
really the towel trick? that doesnt work, ive had so many broken 360s not one was fixed by wrapping it in towels, thats a myth
Old Jul 22, 2010 | 12:51 AM
well then what other way is there to do it?
Old Jul 22, 2010 | 12:52 AM
ramrod1337's Avatar
depends on the code, im not an expert though
or i would fix them myself
Last edited by ramrod1337; Jul 22, 2010 at 12:52 AM. Reason: Automerged Doublepost
Old Jul 22, 2010 | 12:53 AM
3 rings i have always over heated..and i really havent had a problem but 2
i think
pm me ram rod
Old Jul 22, 2010 | 01:10 AM
northvibe's Avatar
Ugh man. E74 is. Video issue, usually the gpu ram chips lifting off the motherboard and is a ***** to fix. The rrod, there is no fix, only temp solutions to extend the life. I get 20 xboxs a week, if they cannot be fixed by a heat gun and new mounts for the heat sinks we have the cpu/gpu reflowed and even that doesn't fix them. The heat sinks are fine, one of the issues is the way they are mounted with the x brackets. The other issues are the lead free solder so the ***** that hold the chips actually melt again and then don't keep contact as the chip lifts off. The other issue is the complete horse crap design of the cooling. So the best way to fix is heat gun and new screws and spacers for the heat sinks. If that doesn't work its not worth the time. Now me believing you want cheap to free xboxs to fix and give away is a whole other issue.
Old Jul 22, 2010 | 01:13 AM
man i still got release date xbox that rr a month later. works great till this day
Old Jul 22, 2010 | 01:18 AM
  #36
northvibe's Avatar
A month after u bought it and you didn't warranty it, you fixed it yourself? **** even MS can't fix their own xboxs. Rallyracer sent his off and got a rrod one back out of the box. Most friends are on 8 or more. X360 is a pos hardware wise. No conesole has failed this bad this much.
Old Jul 22, 2010 | 01:22 PM
  #37
north, i dont wait for microsoft. hell i mostly use linux. easyer just to fix it your self
HEATON
Oct 16, 2015 07:21 PM
Builttss
Oct 4, 2015 10:21 AM
Trav3480
Oct 1, 2015 08:17 PM
