2.2 BETA Test
#201
this may be a little off topic but would i need to get any kind of forged internals or anything else to keep my engine from getting screwed up when i go to get my turbo kit im looking at the garrett kit i just wanna know because i need to know how much money im gonna need to get the turbo kit and have it installed and if there is anything extra ill need then i need to factor those costs in.
#202
if your using the standard hahn tune with 8psi then no. if your gonna up the boost and get near 300hp which from what i read can damange the rods, and pistons, somewhere around 300 and up..
i have been thinking the same as you cobaltdriver..
I have been looking at getting crower rods and diamnond or wiesco pistons in a lower compression.
if you go to crowers page you can get forged or billet rods.. they also have package deals for crankshaft, rods, and pistons from wiesco as well..
id love to get the whole package as just in case for the future. billet rods can handle 700hp from what crowler says.. forged i believe i are 500hp.. forged should be plenty
Eagle also makes rods and crankshafts. It comes down to preference
#204
well from looking at the disc potato turbo they have it says about 350hp, i dont no what boost level that would be cause i believe it goes every 1 boost=10hp
so if at 8psi hits us at 200hp 300hp would be 16psi.. thats if your not counting new 3 inch catback and all.. just a rounded figure or so...
so 350 would be in the 21psi.. if your going to hit that change out rods and pistons quick lol..
#205
um... at 283hp the rods go boom. GM did it. all 4. at the same time. right thru the block. this was on n2o, granted, but if you hit 300 on boost and don't have forged rods.... well... you're an idiot. personally i'd be replacing the rods if i was around 250 just cuz temperature changes could yield a 1-2psi boost spike and there goes your engine.
#206
ok cool thanks for clarrifying that, thats why i said near 300 they should be replaced, i left the gap open..
I wrote in another thread about the rods snapping.. that is why though i said near 300, was waiting for someone else to chime in on my opinion.. i wont be pusing my turbo past 210 until i forge ****..
through the block?? crap..
#207
#209
There was no compression. it was nitrous. The power level was just WAY to much for the rods, causing them to crush and snap in half. They were then thrown threw the block.
#210
Also 8lbs may be "safe" but there is no guarantees when you turbo a n/a car. So all you people wanting turbos keep some money for repairs. Clutches cant handle much over 250 and who knows bout the tranny it self. That part well, clutch and tranny depends on driver really.
#211
i def agree, it depends hugely on the driver, what was it hahn said about having the manual tranny near 400 and up hp??
my boost comparison was just a rounded number.. i have said in another thread that once the turbo is in, that i wanted to change rods and pistons. lower the compression.. i dont have to worry about the clutch as i am auto, i know the torque convertor can get really hot.. i have to get a tranny cooler also..
I meant compression as the piston moving up, sorry sw4 i wrote it wrong lol.. sometimes i cant explain to well..
I got a question, how much boost or hp till i have to change parts of the valve train?? would 310hp require some changes in the valve train??
I no from the build book the auto can take 325lb on the gearbox, which i wont hit that most likely, depends on what i decide down the road.. i no there is another auto tranny i could throw in the car if something happens, i forget the name.. its the performance tranny, ugg cant remember..
I am calling crower when i want there forged rods, if you look on there site, they got both billet and forged for our car, but the forged would be enough..
i will either get wiesco or diamond pistons.. 8.9.1 pistons..
#212
Good link for those of you who dont have this.....
http://tunersource.gmblogs.com/Racer...nce-build-book
-2.2 rods not reccomended for use over 250hp
-pistons tested close to 300hp but reccomend change at 250hp
-intake mani. tested to 350hp range
-valve springs only allow up to 7500rpm
-stock cams good to 400hp
-head with production valves ran to 500hp on gas with 24lbs of boost
out of the build book read it if you havent!!!!!!
#213
so upper the Rev limiter won't do much unless we get cams to help the powerband or is there still enough power to justify staying in the higher RPMS? I'm just kinda wondering if we would see gains at the track with just bolt ons and a 2.4 manifold. Seems like it wouldn't kill us if the limiter was at 6800 or 7000.
#214
I'm old school
People, you are getting grossly ahead of yourselves. Focus on the problem at hand, that being the ability to flash the E16a computer in the aftermarket. If this simple hurdle can be jumped, the rest is cake.
#215
not true.all you have to do is lower the compression and put the lsj rods in it and a good head gasket and youll be good.in the ecotec performance book it states the stock l61 crank is good for 550 hp and cams are good to 450hp!just lower the comp. with good rods and head gasket and you can hit some really good boost numbers!
#216
True, but we all want 10,000k rev limiters, 300mph spped governors, and quad turbos!
#217
#218
After taking another look at the build book.. before i have the turbo, crower will be getting a call for a package deal they have. you can get forged or billet rods, and wiesco pistons for a discount package.. only need forged rods though
EDIT: Halfcent, Vince was told about the PE delay by tom, I asked him today
#219
#220
I'm old school
Unless you are planning on making over 600 HP, the crower rods are a waste. Have you actually done any shopping yet? Those rods are over a thousand dollars. The Eagle rod set can be had for under 400.
And I agree, I have yet to hear about any progress on the PE issue.
#222
crower makes both billet and forged, its on there site halfcent, the crowers the 694.99 which isnt cheap lol and yea the eagles are 329.99.. The reason i was going to go with crower is because of there package deals on rods and pistons, and they sell it both in forged. If it isnt cheaper id just go with eagle rods and wiesco 8.9 pistons.. The limit of forged rods is 500hp right??
I do not know the status on PE delay, Tom told me as a update as i havent been in contact with Vince i the past few days.
I will keep pushing hard for the software tune as that really seems to be everyones main interest over the GT tuner.
#223
I spoke to Vince last night, he said the shop has been SUPER busy. they apparently got a boat load of work in in the past few days, and he's been trying to keep up.
#224
oo ok.. I no Tom goes to his shop this weekend to hook the tuner to his car to get the numbers out of it and what not, then the tuning will be started and soon followed by dyno on either that day or later on..
he thinks its busy now, wait till tuning is done, he will have cobalts in the area fludding him lol
#225
lol that's what I said... he said something to this effect "yeah, but that 2.4 guy, he's really getting all my attention, he's the one I'm really worried about."
hahahahahahahaa j/p j/p - seriously tho.... 2.4 love, show it.
