F 35 transmission rebuilds
Allot of variables.
Mostly driving habits and torque curve. higher rpm boost / torque peak is more forgiving.
Someone with 300whp/wtq and an unforgiving clutch could screw up just about any transmission.
Little things like preventing wheel hop, using a forgiving clutch and not using super sticky tires can help save your trans as the clutch or wheels will likely spin before the trans breaks and if it does spin it won't smash the hell out of your transmission.
The 4.05 and 4.45 aren't actually stronger then the 3.86 it's just geared more forgivigly letting the engine put down the power without cranking on the internals as hard.
Allot of variables.
It's much not capable of holding power but can still be broken.
the zzp mounts are regrettably not rotated so the root cause of power hop is (also regrettably) not addressed.
trans breaks immediately in power hop and thats a fact.
some good posts on here ^^^^
I wouldn't chance it, it's either 4.45 or F40, it may hold up for a bit but still won't be as strong as either of the other two better options. If you want a stock LSD 4.05 I'd say go for it but don't spend the money on a built one.
Thank you i guess I'm going f40 then i dont want to drive highway withbrevs over 3k with the 4.45
By the way at 70mph with a 4.45, you'll be right 2800rpms. Not a big deal.
Damn..about 6 years ago when i busted my trans i paid about 1200 for a junk yard unit that sounds like its grinding coffee 90% of the time (still works find ). I would have jumped all over this.
If we source a transmission with a 4.45 gear set can we dissemble it and just send you the ring and pinion? Would you need anything else from it? Would the pricing still be the same if we shipped you the 4.45 along with a 3.82 lsd core?
Yes but be cautious. I receive trans where people have attempted to dismantle them and by hammering on the mainshaft (which is the pinion also ) they wreck it.
