Foam Gun Group Buy.....
Old Mar 6, 2008 | 05:47 PM
Chris(NJ)'s Avatar
This was requested for a 3rd time on another forum, and since the minimum has already been met, I wont require one here. Heres the info... any questions, please let me know
The proportioners are changed via 15 different sized tips, each with a different diameter opening to allow the soap/chemical to pass through. This allows you to adjust how much or how little solution is used. I used a slightly larger tip during initial testing, but have bumped it back down for everyday use to save some product. Foam guns save time when washing, and allow your solution to start working on breaking up surface dirt and pulling it away before you start to wash w/ your mitt. And if for nothing else, they are a blast to use, lol. Makes washing fun :crazy:
Heres whats included and how it works;
Foaming barrel, pistol handle and 48oz container. Simply screw on your pistol handle to any standard garden hose. Pour in your wash solution into the 48oz container. Choose your tip size, and put into base of eductor/barrel, then slide pull hose over it. Screw on the top/barrel. Youre now all set up. Wet down your car, then attach the barrel/container to your pistol handle via quick disconnect. Begin foaming Simple as that :head:
Heres some shots of the new foam gun in use.
Retail pricing is set at 58.95
Your forum discount would put it at 50.10
Please remember your regular forum discount to get the prices to the ones listed below. Since this is only temporary, you wont see any descriptions or pics on the site for these deals. Just figure out which of the below options you'd like, than find the corresponding option in the specials section. Its pretty easy to figure out, but pm/email me if you have problems. You can still place any other items from the store in your cart and your regular discount will still apply to those as well!
http://www.glimmerglassdetailing.com/specials.html
I'll run this group buy for the next 12 days!, which ends it on Sunday evening, the 16th. That should give everyone ample time to jump in
Option A: Foam Gun. 44.85
Option B: Foam Gun. Gallon of Super Slick n Suds: 77.56
Option C: Foam Gun, 32oz Super Slick n Suds, Sheepskin Wash Mitt, 24x36 WW Drying Towel. 79.05
Option D: Foam Gun, 32oz Optimum Car Wash, Sheepskin wash Mitt, Foam Core WW Drying, 24x36 ww Drying, Optimum Quick Detailer: 99.88
Option E: Foam Gun, 5 Gallon Wash Bucket, Grit Guard, 1 Gallon Super Slick n Suds, 16oz Bug Squash Bug and Tar Remover, 32oz APC (all purpose cleaner), 32oz Bold n Bright Tire Dressing, 32oz Spray n Gloss Quick Detailer, Foam Core Waffle Weave Drying Towel, 2 Elite Microfiber Towels, 2 Microfiber Applicator Pads. 141.10
Old Mar 6, 2008 | 06:53 PM
UmeNNis's Avatar
foam bump
Old Mar 6, 2008 | 08:01 PM
Krimson_Kobalt's Avatar
dang... if only it was warm out so i could use it
that would save me a lot of money from car washes
Old Mar 6, 2008 | 08:11 PM
Chris(NJ)'s Avatar
sooooon vveerrrrrryyyy sooooonnnn
Old Mar 6, 2008 | 08:19 PM
silentd's Avatar
i wouldnt mind that, but not for 50 bucks
Old Mar 6, 2008 | 08:43 PM
Chris(NJ)'s Avatar
Seems like a lot, I know, but trust me, it's worth it. Since I started carrying this brand about 16 months ago, I've gone through about 150 of them.
Consider another option. The gilmore foam gun, which runs 15-20 dollars more and has less proportioning adjustments! Plus, w/ the gb, this one comes down to 45 +s&h.
Old Mar 6, 2008 | 08:47 PM
vB00STw's Avatar
I just have a question...Doesn't a fertilizer gun work the same way? Why couldnt you use one of those? Not putting down the product but just curious.
Old Mar 6, 2008 | 08:58 PM
Chris(NJ)'s Avatar
Similar, but no. A fertilizer type gun can work well for a prespray of APC which wouldnt require the foaming action. They make a seperate product for this actually. This one does have an air inlet to promote the foaming plus a larger inlet area.
And I dont mind the inquiry. I've had guys ask (and test) the same type of product you mentioned and wound up purchasing this from me afterwards. Thats why I really dont mind when people make the comparison b/c I know this one outperfoms a homemade version from home depot
Old Mar 6, 2008 | 10:16 PM
roccobladr's Avatar
can you use whatever kind of soap you want? ive always wanted one of these guns, but i am particular about what stuff i use on my car
Old Mar 6, 2008 | 11:13 PM
Chris(NJ)'s Avatar
yes, you can use any type of soap in it.
Old Mar 6, 2008 | 11:43 PM
roccobladr's Avatar
oh sweet! anything that needs to be refilled or anything? or do i just my own soap whenever i want and good to go?
Old Mar 7, 2008 | 07:13 AM
Chris(NJ)'s Avatar
The only refilling thats required is of the soap youll use while washing
Old Mar 11, 2008 | 11:24 PM
Chris(NJ)'s Avatar
5 days left
Old Mar 15, 2008 | 09:44 PM
Coop's Avatar
Chris how do I order? Went to your site following the links and dont see it.
Old Mar 15, 2008 | 09:46 PM
leadfoot's Avatar
first thing that came to mind...
N.E.R.F.
Old Mar 15, 2008 | 09:53 PM
AROON02's Avatar
yyea sorry that thing is def not worth 50 bux
Old Apr 2, 2008 | 02:14 AM
tkosmen's Avatar
i want to buy one.....how do i order?
riceburner
Mid Central
Oct 5, 2015 09:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
Extreme Dimensions
Sep 24, 2015 05:24 PM
dennis69
Sep 22, 2015 08:33 PM
