Front Mount Heat Exchanger Group Buy
Old May 19, 2008 | 02:05 PM
Eng@RebelAutoWorxs's Avatar
We finally finished off installation and testing of our new Front Mount Heat Exchanger which runs in parallel with the stock intercooler heat exchanger. The HE sits just behind the front lip for maximum air flow. It is over 3" thick with a dual pass built into the HE which increase its efficiency.
Included:
Aluminum mounting brackets
Stainless hardware
Heater Hose
Stainless clamps
Full Instructions
Results:
Test vehicle: 2007 2.0L Cobalt running GM Stage 2
Before:
Temps went from 82*F to 124*F = increase of 42*F
After:
Temps went from 77*F to 115*F = increase of 38*F
This was a single gear pull on a cold day, there should be larger temperature drops on a warmer day specially at the track. There would also be better gains during multiple gear pulls.
Other enhancements noticed:
* Faster drop in temps after a run
* Lower cruising temps
Before:
After:
Price:
Regular $440CDN
With a minimum of 10 orders we can reduce the price to $375.99CDN
Old May 19, 2008 | 02:09 PM
jimbos'ss's Avatar
wow that thing hangs low
Old May 19, 2008 | 02:12 PM
impulseballer's Avatar
dam that's some serious coin lol
SlowBalt_06's Avatar
wow yes it does and cost more the the ca one
lsjwannabe's Avatar
that car was knocking bad lol
Old May 19, 2008 | 02:14 PM
RedEcotecSS's Avatar
whoa pricey
Old May 19, 2008 | 02:15 PM
dont worry that was one of the tunes they sell
Old May 19, 2008 | 02:44 PM
our prototype model hung a bit lower than we wanted. Production one will hang in line with the front lip and also the drain plug is moved to the side instead of below.
that's actually GM Stage 2
Last edited by Eng@RebelAutoWorxs; May 19, 2008 at 02:44 PM. Reason: Automerged Doublepost
Old May 19, 2008 | 02:46 PM
Rodimus_Prime's Avatar
Funny how my 07 with stage 2 never had any knock or ever went over 25 more than ambient, if IAT1 is 45 IAT 2 shouldnt be 115, also looks like COT is kicking in, might want to find a better car to test with that one has some issues to be worked out
Anyways is that painted, it might look better just aluminum
Old May 19, 2008 | 02:47 PM
Drakonen2000's Avatar
so many group buys!!!!! ahhh!!!!! no money left!!!!!!!!
Old May 19, 2008 | 02:52 PM
this guy has intake, 3.5TB, header, cat back, this is a good example of why you need tuning with even simple bolt on.
This HE is copper/brass (has better heat transfer than Aluminum) so that's why it's painted. It is about 1" thicker than the CA, it's built in a week so not too much of a wait.
Old May 19, 2008 | 02:57 PM
Good call, if ppl knew it was copper they would yank it right off your car!
Old May 19, 2008 | 04:18 PM
UmeNNis's Avatar
What exactly does it bolt onto? Do you need to drill?
Old May 19, 2008 | 05:28 PM
ecotecon18s's Avatar
holy injector duty cycle batman!!!
Old May 19, 2008 | 06:58 PM
bigrroberto's Avatar
that's why it cost so much, its made of copper. I can see that working better so It's probably worth the money...
Old May 29, 2008 | 04:05 PM
ebristol's Avatar
What are the exact dimentions?
Is that made from two cores?
Would it be possible to make on with one core so its not so think?
Old May 29, 2008 | 04:17 PM
Mss26's Avatar
wow.. i was excited to see this post since I'm from canada and I wouldn't have to get bent over on shipping from the US but thats more than I expected....
can you post some pictures of the non-prototype one to see the fitment etc?
Old May 29, 2008 | 04:27 PM
Raven SS's Avatar
am i missing something? i look at the logs and i see a 2 degree drop between the before and after log...im not math magician but im pretty sure thats what i see..
Old May 29, 2008 | 04:34 PM
stonny9's Avatar
It's a heat exchanger so u know ur gonna get a decrease in iat2 if the end user actually hooks it up right.
Old May 29, 2008 | 04:41 PM
Raven SS's Avatar
lol...yea im not new to this..just cant spend 440cdn for a 2 degree difference when my cx racing has provided a 17-21 difference everyday
Old May 29, 2008 | 04:49 PM
Mss26's Avatar
Where are you seeing this? I'll be honest I'm not a tuner and I don't know what those things (graphs) mean. But I was looking at the IAT2 line In Farenheit, and I think the peak is 122 vs 115.
In other words, where should I be looking if you don't mind "learning" me a bit lol.
Old May 29, 2008 | 04:57 PM
Raven SS's Avatar
iat is the air inlet temp then iat2 is in the manifold...the difference between the 2 on before is 72*'s...on log number 2 the after its 70*'s difference
Old May 29, 2008 | 05:06 PM
Mss26's Avatar
Okay I get it, 124 - 52 = 72 and then after 115-45 = 70 and so the difference of 2.
I always hear people talking about the IAT2's so I though it was simply to get that peak number lower. But now I see your point, and it makese sense. Thanks
Old May 31, 2008 | 09:47 AM
we are going to test the front mount on a car running a 2.7 pulley and our tune.
We will also do a couple gears in a row to see the differences.
Last we have been talking to our supplier and we can probably drop the price another $40.
Old May 31, 2008 | 11:14 AM
Tennpenn83's Avatar
wow... 134% injector duty cycles...
