Front Mount Heat Exchanger Group Buy
We finally finished off installation and testing of our new Front Mount Heat Exchanger which runs in parallel with the stock intercooler heat exchanger. The HE sits just behind the front lip for maximum air flow. It is over 3" thick with a dual pass built into the HE which increase its efficiency.
Included:
Aluminum mounting brackets
Stainless hardware
Heater Hose
Stainless clamps
Full Instructions
Results:
Test vehicle: 2007 2.0L Cobalt running GM Stage 2
Before:
Temps went from 82*F to 124*F = increase of 42*F
After:
Temps went from 77*F to 115*F = increase of 38*F
This was a single gear pull on a cold day, there should be larger temperature drops on a warmer day specially at the track. There would also be better gains during multiple gear pulls.
Other enhancements noticed:
* Faster drop in temps after a run
* Lower cruising temps
Before:
After:
Price:
Regular $440CDN
With a minimum of 10 orders we can reduce the price to $375.99CDN
Included:
Stainless hardware
Heater Hose
Stainless clamps
Full Instructions
Results:
Before:
After:
Before:
After:
Price:
Regular $440CDN
our prototype model hung a bit lower than we wanted. Production one will hang in line with the front lip and also the drain plug is moved to the side instead of below.
that's actually GM Stage 2
Last edited by Eng@RebelAutoWorxs; May 19, 2008 at 02:44 PM. Reason: Automerged Doublepost
Funny how my 07 with stage 2 never had any knock or ever went over 25 more than ambient, if IAT1 is 45 IAT 2 shouldnt be 115, also looks like COT is kicking in, might want to find a better car to test with that one has some issues to be worked out
Anyways is that painted, it might look better just aluminum
This HE is copper/brass (has better heat transfer than Aluminum) so that's why it's painted. It is about 1" thicker than the CA, it's built in a week so not too much of a wait.
wow.. i was excited to see this post since I'm from canada and I wouldn't have to get bent over on shipping from the US but thats more than I expected....
can you post some pictures of the non-prototype one to see the fitment etc?
In other words, where should I be looking if you don't mind "learning" me a bit lol.
Where are you seeing this? I'll be honest I'm not a tuner and I don't know what those things (graphs) mean. But I was looking at the IAT2 line In Farenheit, and I think the peak is 122 vs 115.
I always hear people talking about the IAT2's so I though it was simply to get that peak number lower. But now I see your point, and it makese sense. Thanks
we are going to test the front mount on a car running a 2.7 pulley and our tune.
We will also do a couple gears in a row to see the differences.
Last we have been talking to our supplier and we can probably drop the price another $40.
