GROUP BUY: Koni Yellow Shocks!!!
Old Jun 27, 2008 | 05:35 PM
thmotorsports's Avatar
Originally Posted by eazyasone23
this is a steal of a price and adam is a good guy. this is probably one of the best mods you can do. thanks adam for the update hopefully i will get them before saturday to install them on my day off. ill post pics when they are installed
thanks for the warmness!!
get them guys!!!
you guys are always asking for them when they are on backorder!!!
They are in stock!!!
Ready to ship!!!
Adam
Old Jun 30, 2008 | 04:06 PM
come on guys!!!
ready to go!!!
Old Jun 30, 2008 | 11:40 PM
eazyasone23's Avatar
The shocks are amazing. They handle so well. They are adjustable, they ride firm, not harsh or bouncy but they are definitely firm.
Old Jun 30, 2008 | 11:48 PM
tsunam1's Avatar
will they get rid of that load thud I get when I drive over any kind of bump in my car? I assume it is because I am bottoming out on the bumpstops because the car is dropped 2" and the original struts dont absorb it anymore.
Old Jul 1, 2008 | 01:23 AM
i did notice the car is a lil more quiet than it was. i go over speed bumps to work all the time. but i still get a lil noise from my sway bar, so imma upgrade my sway bar links soon, but the car does make less noise. my car is fairly low and i wasn't having to many problems, but i was getting noise from other worn suspension parts.
Old Jul 1, 2008 | 01:29 AM
picsbypenny's Avatar
how hard is it to install onto my 08 cobalt ls
Old Jul 1, 2008 | 02:46 PM
frost289's Avatar
Hey Adam how much to l7g3g7.usps preferred
Old Jul 1, 2008 | 04:39 PM
with proper tools and some experience it should take you no longer than 3 hrs if you are doing it yourself. personally i dont think its hard, you just need patience and some time
Old Jul 1, 2008 | 05:03 PM
The stock struts cant handle that....the piston inside becomes fatigued and does not work properly in your case...soon enough you will blow your OEM struts
BTW the Koni Yellow sport shocks have a lifetime warranty on them.
Adam
Old Jul 2, 2008 | 02:41 PM
Pm's sent!!!
We can ship to Canada!!!
Old Jul 3, 2008 | 01:43 PM
  #36
thanks guys...
i lost track of the last 2 guys who purchased...I did not receive their forum names
Adam
Old Jul 3, 2008 | 02:51 PM
  #37
o3nisoaso3's Avatar
Originally Posted by thmotorsports
thanks guys...
Adam
amazing price!
Old Jul 4, 2008 | 03:19 PM
  #38
Ramphex's Avatar
I know it's a noob question, but what do you mean they're adjustable?
Old Jul 4, 2008 | 07:14 PM
  #39
you can adjust the damping. for handling purposes and spring rate purposes.
Old Jul 5, 2008 | 12:54 PM
  #40
stenguyen1's Avatar
u know how they say adjustable shocks. well i got the rear shocks in and i don't know how to adjust them. or can they not be adjusted?
Old Jul 5, 2008 | 12:59 PM
  #41
sherm420's Avatar
they can be adjusted too ill get u the link
https://www.cobaltss.net/forums/show...ight=koni+club
REAR
Rebound Adjustment Procedures
Remove the shock absorber from the vehicle and hold it vertically with the lower eye or pin attached in a vise. Use clamp plates to prevent damage.
Fully collapse the shock absorber, at the same time turning the dust cap or piston rod slowly to the left (counterclockwise), until it is felt that the cams of the adjustment nut engage in the recesses of the foot valve assembly.
The damper may have already been adjusted. Therefore check whether the shock absorber is in the adjustment position or not by keeping it collapsed and gently turning it further to the left counting at the same time the half turns until a stop is felt. Stop turning then and do not use force.
Keeping the shock absorber collapsed, make 1 half turn (180 degrees) to the right (clockwise). In case of prior adjustment add the number of half the turns previously found. The total range is about 5 half turns.
Pull the shock absorber out vertically without turning for at least 1 cm to disengage the adjusting mechanism. The dust cap or piston rod may now be turned freely.
ADJUSTING DIRECTION
Clockwise = Firmer
Counter Clockwise = Softer
Old Jul 7, 2008 | 03:43 PM
  #42
REAR
ADJUSTING DIRECTION
Clockwise = Firmer
NICE!!!
I love the KONI CLUB!!!
Old Jul 7, 2008 | 04:59 PM
  #43
stenguyen1's Avatar
so is there a how to for that? cuz i don't wanna **** anything up when i try to adjust the rear shocks.
thanks for telling me how to adjust them.
Old Jul 8, 2008 | 06:14 PM
  #44
Grich171's Avatar
i will be ordering a set for the rear verry soon cant wait
Old Jul 8, 2008 | 07:25 PM
  #45
let me know guys!!
Old Jul 9, 2008 | 05:41 PM
  #46
bump!!!!
Old Jul 10, 2008 | 03:15 PM
  #47
local pickup is always welcomed!!!
Old Jul 10, 2008 | 04:12 PM
  #48
drewski's Avatar
do you know how much these would lower an LS with stock springs, if at all? i do a lot of Auto X and in order to stay in the same class (h stock) i can only upgrade shocks, not springs, so i was wondering if i would get a semi-decent drop since i really should get new shocks
Old Jul 10, 2008 | 05:03 PM
  #49
no drop at all
Old Jul 10, 2008 | 05:07 PM
  #50
drewski's Avatar
no drop at all
yeah i didnt think so, oh well
