HID Kits $130 shipped!
Hey I have a question I just ordered some headlights from you guys which are pictured as 3rd gen headlights but the bulb you say that goes with it is H7 shouldnt it be H1 or is the picture wrong ( i hope its not the picture) lol
Woot Just ordered some 8000k H1's can't wait to put them in...
I about crapped myself when I ordered them and then saw you had the same projectors on your site but said H7 bulbs but then i saw where you told stg2ss they were h1 and then I could breath again lol..
i was reading the discription for the 3rd gen headlights and it reads:
Direct Plug and Play bolt-on on part
New high quality JDM version taillights
Designed as direct bolt-on replacement parts
Perfect fitment and no modification required
Water and shock resistant
Make and Model Specific
100% brand new
Complete set includes left and right side
S.A.E / D.O.T approved and 100% street legal
just an fyi since ive been looking at getting these once i get my refund.
100% brand new
So if you want custom blue, just select the custom blue
Yes they do, they are the same kit size 9007.
Just ordered my kit operatic! Under the email pimpn4u14@aol.com or Madsen259@aol.com
So are these shipping next day air? it says shipped overnight so im confused...
Question, reading on your site it says "HID low beam, halogen high beam" so in the one bulb there is the HID and low right? Cus I've heard that with HIDs you lose the high beam. I don't mind if the high beam is halogen since I wouldn't be using it at meets and stuff anyhow.
i can answer this one good sir... your bulb will compose of a double bulb. there will be your Low beam HID will look kinda like a rod with a bubble in it. then right beside it tightly is an H1 bulb which is your halogen bulb. thats your high beam. not nearly as bright as the HID of course
this is basically what it will look like
that is correct. I still love my HIDs. almost two years and I couldn't be happier.
you will obviously know that the low beams will be WAY brighter than the halogen high beams. its great that you will have the highs for inspection, but you will notice you will hardly use the highs because of how well the HID low beams work.
how is the quality of these..im having issues with my current HIDS.pretty sure the 1 ballast is going..mite just buy the plug and play kit h/l hid set....i had 6k..wuts the big difference up to a 8k
what symptoms do you have? The easiest way to pin point a ballast or bulb problem is to take the bulb from the left and swap it with the right or vise-versa. If the problem follows the swap, then its a bulb. If not, its a ballast. Altho, its not a terrible idea to make sure all of you electrical connections are tight, clean, and corrosion free.
and the only difference between your 6k kit and the 8k is just that the 8k will be much more blue.
