Purchase a TTR Upper Mount get Prothane Transmission Bushings At A Great Valve!
so you get the upper engine mount for like $219.00 plus if yuo want the poly insert its gona be $258.00 and then if you also want you guys are now offering both front and rear tranny mounts for another $39.00 which would bring the whole kit to a grand total of $297.00 US plus shipping? Am I understanding this right? Also... the two tranny mounts are just the red inserts correct?
At the time you purchase the TTR upper you have the choice to purchase the Prothane tranny bushings for ONLY $39.99 (set of 2 red bushings and aluminum sleeves) Most places sell these 2 bushings for about $60.00 so you save $20.00 or so
So you can get a COMPLETE set of 3 mounts for only $219.98 + ship.
This is by far the best value in mounts avaliable today as far as we know.
Trust me its worth it! The vibes are noticable at idle but nothing like i thought it would be and the car is so much easier to launch and the shifts are so much smoother. I reved the engine with the hood open before the mount and the engine noticably moved alot and with the mount the engine is solid and didnt move at all when reved!
I JUST INSTALLED THE TRANS BUSHINGS!!!!!! Aaron, I'm Really Really happy with the Motor Mount + Trans Bushings! I was a lil frustrated with just the Motor mount, untill like last week. But now that the Trans Bushings are in man, No wheel hop, all wheel spin. I'm over joy'd. Thanks again.
p.s Getting that stock bushing out might have been one of the most frustrating things I ever did the 1st time. Once I did it, the 2nd one was cake.
p.s.s Any1 thinking about this should jump on this deal B 4 its over! AWESOME PRODUCTS!
Doing just the TTR mount is only doing 1/3 of the job, you need the Prothane tranny bushings also to do the job right, which this setup should eliminate most if not all wheel hop.
i installed the motor and tranny mounts and everything went in easy and everything is straight. but are you supposed to feel EVERY vibration from the engine especially when you rev or take off?
You will feel some, however most will go away within 500 miles being on the car.
roth
Sep 26, 2015 12:16 PM
