Spec Clutch and Rotated Mounts Deal
I currently have two spec 3+ clutches on the shelf for the lsj. If you buy one at full price, $799.99. I will throw in a set of our stage 2 mounts for free.
SPEC Stage 3+ Clutch Kit 2.0L LSJ - Over The Top Performance
I also have three spec 2+ clutches for the lnf on the shelf for the same deal as above.
SPEC Stage 2+ Clutch Kit 2.0L LNF 08+ - Over The Top Performance
When you order add the clutch to the cart and a set of stage 2 mounts, at checkout use coupon code freemounts and the $200 for mounts will be removed from your order.
