'06 LS going warping brake rotors in less than 5k miles
Old Jul 25, 2012 | 06:56 PM
R1600Turbo's Avatar
Anyone else have issues with this? Some of you might remember my other post where I had a bad knocking sound under braking. Turned out to be a warped front rotor paired with old control arm bushings and the crappy ass steering column they put in these things.
I replaced the front rotors with a pair of EBC units ($90) and it went away for a while. Now, less than 5k miles later, I can feel it in the brake pedal and hear the column making noise again.
What else could be wrong with the car to cause it to warp the left front brake rotor twice in less than 10k miles?
I might be letting the car go back (repo) soon because there is no way I can sell it for what I owe, and there is no way in hell I'm keeping it long enough to get it to that position or pay it off. As soon as I can scrape together enough money to pay cash for a car, this one is going back.
Old Jul 25, 2012 | 07:07 PM
Powell Race Parts's Avatar
ebc are not nice rotors. sad for your story. take the easy way out and live with bad credit reports?
Old Jul 25, 2012 | 07:44 PM
R1600Turbo's Avatar
I have bad credit anyway. If there is an easier way to get out of it, I'm all ears.
EBC are better than Autozone cheapies.
Old Jul 25, 2012 | 08:42 PM
tru2nrtt777's Avatar
My stock rotors warped at 5k, turned them and went out again around 15k. Bought EBC slotted and they warped around 40k... I have just been saying f it and running warped since. I am on 73k now.
Old Jul 25, 2012 | 08:45 PM
Sunburst_SS's Avatar
what pads do you have?? The factory semi-metallic pads are rough on the rotors........also, depending on how you brake while driving will be a factor also.
Old Jul 25, 2012 | 08:55 PM
First two times stock pads, when I swapped to EBC's I swapped to EBC Yellows in the process.
Old Jul 25, 2012 | 09:16 PM
I can say nothing good about ebc pads, customers come in here with the EBC pad material falling apart. not nice.
ac delco do an advantage series of rotors that are well priced, dont warp even in reasonably hard driving. But some folks can wreck anything i guess.
Old Jul 25, 2012 | 09:29 PM
IDK, my yellows have held up fine for around 35k which include several autocrosses and one VIR event.
Old Jul 26, 2012 | 12:16 PM
R1600Turbo's Avatar
Not sure on the pads. When I drove the car off the lot it had new pads, so I didn't bother changing them when I swapped to the new rotors.
I'm still trying to figure it out. I don't feel anything when I'm lightly braking, but if I have to brake harder I can feel sort of a "thump, thump, thump" through the pedal and can hear the steering column knocking around.
Been looking for a low mileage car in the junk yard to pull several parts from, (column & shifter) no luck so far.
Old Jul 26, 2012 | 12:45 PM
emiller's Avatar
It's only the left front rotor? Maybe your brake is dragging.
You are gonna to further wreck your credit over a 7 yr old econo car getting repoed? Stupid idea.
Old Jul 28, 2012 | 10:10 PM
Nocturnal Sheep's Avatar
Sounds like your slides are sticking or your rotor isn't sitting properly.
Old Jul 31, 2012 | 05:45 PM
R1600Turbo's Avatar
Not sure how the rotor can't be sitting properly. Wheel is on and torqued down.
Hasn't really gotten worse, so I'll be keeping an eye on it until I get rid of the car. May have someone taking over payments.
Old Jul 31, 2012 | 06:06 PM
LS6Rally's Avatar
take the rotr back off and check to make sure here is no debris stuck behind the mating surface. check to be sure your caliper slides are working as well. can you spin the left front freely when it is jacked up?
Jan 12, 2016 12:01 AM
deviance
Nov 24, 2015 05:51 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
