07 cobalt ss suspension & brake parts
Old Mar 20, 2019 | 11:29 AM
Johnny Bliss's Avatar
looking to do my cobalts front end, its getting sloppy, brake rotors are warped. ive already done the tie rod end links and i have a new steering shaft (the one on it isn't sloppy yet)
anything better / the same / cheaper out there i should know about?
suspension
zzp springs and kyb excel shocks front and rear sway bars
https://zzperformance.com/collection...ring-springs-1
https://zzperformance.com/collection...excel-g-struts
https://zzperformance.com/collection...front-sway-bar
https://zzperformance.com/collection...-rear-sway-bar
front end rebuild
https://www.rockauto.com/en/moreinfo.php?pk=6385356&cc=1433737&jsn=1036&jsn=10 36&jsn=1036
brakes
https://www.rockauto.com/en/moreinfo.php?pk=3797304&cc=1433737&jsn=505
Old Mar 20, 2019 | 12:29 PM
michael23v's Avatar
powell springs. powell sway bar
Old Mar 20, 2019 | 01:03 PM
jdbaugh1's Avatar
If you have SS then I would leave in the stock front sway bar but like michael23v said, a Powell rear hardcore sway-bar is my preference. People often say go for the XXX swaybar but I find the rear hardcore bar combined with a front 24mm that I still have plenty of rear end rotation. I even drop the pressure in my rear tires a bit as otherwise I get excessive oversteer during autocross. For spring shock combo I really think stock FE5 TC Cobalt shocks/struts with Powell's YYZ springs is ideal for the street. I used to have FE5 TC Cobalt shocks paired with my YYZ springs and later switched to Koni and TBH I couldn't tell the difference. I'm sure there are experts that would scoff at that but for the street FE5 OEM is really pretty good. Check trailing control arm bushing. The voided bushing rots away. Replace with a solid rubber bushing at the very least or swap to Powell or OTTP spherical.
Old Mar 20, 2019 | 02:08 PM
I got some push back from the boss...
I see cratenegine depoy has the fe5 hhr shocks and struts for $390 I'll have to keep my original springs which I'm ok with...
Old Mar 20, 2019 | 02:11 PM
I might have to put stock replacement brake rotors on it doesn't look like the eBay slotted rotors are much cheaper than the powerstop ones
Old Mar 20, 2019 | 02:13 PM
I guess they are a lot cheaper.
https://rover.ebay.com/rover/0/0/0?m...2F400731842546
Old Mar 30, 2019 | 12:52 PM
Put the eBay rotors on. They seem ok. Painted calipers cause they looked shitty
Probably mostly for looks
https://photos.app.goo.gl/tN1awScqU78CfZVMA
Old Mar 30, 2019 | 01:02 PM
ProfDNS's Avatar
^ Those are about $50 less than what I paid. Good find, hopefully they work out.
Old Mar 30, 2019 | 01:05 PM
They work great when they get heat into them
I need to bed the pads better front driver I'd making a little noise
Going to try and get it handled today
I really need new shocks I don't think these on it are the stock ones
The fronts clunk bad. The lower control arm bushing seem fine but the shocks look old and worn out. The debris guards on the fronts are messed up
Old Mar 30, 2019 | 07:23 PM
Got the brakes broke in stops pretty good. Looks cool
Old Mar 30, 2019 | 09:19 PM
ProfDNS's Avatar
If they don't surface rust too bad with wet weather, I'll consider these when I need to do mine again.
Old Oct 8, 2019 | 01:14 PM
ProfDNS.
the rotors still work great and stop great, no rust or anything wierd
Specialized
May 5, 2019 07:41 PM
DCsnow1000
Jun 10, 2013 05:30 PM
InitialG
Apr 20, 2013 12:07 PM
boltedbalt
Feb 9, 2013 11:03 PM
08ShowbaltLS
Dec 15, 2010 05:52 PM
