09 ss/tc rotor install problem
Old Mar 29, 2011 | 02:52 PM
bspeed's Avatar
first time installing destroyed rear rotors on this car. 17k already shot blah blah
well i went to slide my pads into the caliper and it was a no go. the piston would not compress. parking brake was off car in neutral with the wheels blocked. resivour cap was open, used a c-clamp to compress the brakes ended up bending the c-clamp idk what im missing obviously not doing something correct. even opened up the bleeder screw and still nothing fluid came out but the piston wouldn't move.
changed my rotors and pads on my old cobalt and even though it had drums in the back the fronts were a cake walk, piston compressed like normal and never had this problem before.
any help would be great
thanks/
Old Mar 29, 2011 | 02:58 PM
BLAZIN07SS's Avatar
I'm too JDM for you
hopefully you didn't destroy your calipers. the pistons spin in, not compress
HB_SS/TC's Avatar
You're supposed to twist it as well I believe
Old Mar 29, 2011 | 03:06 PM
bspeed's Avatar
i read the how to wow i must not if read it close enough what is the special tool for the piston called?
Old Mar 29, 2011 | 03:07 PM
Chevycobaltss3's Avatar
Yep twist them bitchest
Old Mar 29, 2011 | 03:11 PM
cobalt blue's Avatar
Since the parking brake set up is incorporated into the rear calipers you need to twist the caliper pistons in, you can go to any auto part store and ask for the special tool just tell them you need it for twisting in your caliper pistons, the kit is probably like 50 bucks or so. Good Luck!!
Old Mar 29, 2011 | 03:17 PM
08SSTCRD's Avatar
This is why people shouldn't try and service their own brakes when they have absolutely no idea what they are doing.
You probably ruined the calipers.
Buy a master disc brake tool set or a caliper piston retractor and see if they will spin in, if not you'll need new calipers.
Old Mar 29, 2011 | 03:18 PM
Gixxercobaltdriver's Avatar
bought mine off of EBAY for 15 bucks, ofcourse it doesnt fit but it does get the job done.
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
