2.2L Rear Disc Brake Conversion?
I was thinking about this the other day since I put on my EBC rotors. Does anybody make just a caliper and bracket for it? Cause really thats all I would need, I'd just go get the old rotors turned and reuse those. Unless you actually have to replace the hub as well. Anybody know?
Yea but I don't wanna spend 3k on bigger brakes, I don't want the larger rotational mass.
you dont want the larger rotational mass!? I dont think you'll tell a difference. My dad's 07 ZO6 has some MONSTER brakes, as detailed as they were with that car, I think if it mattered they would have done something different. When I drive that car thats one of my favorite things, is smashing the brakes from 100mph, I go 0-100-0 and it is awsome
I would get the SSBC kits IF you can afford them, otherwise just upgrade what you have.
Also the brakes on the Z06 are one of the cars weakest points. You go on the Vette forums or to a GT3 road race and you wont see guys talking about how good the Z06 brakes are. They are all ditching them.
If you upgrade to the SSBC rear discs, youll now have 10" front brakes and 12" rear brakes......not too good for your brake balance and looks ghey to boot.
If you were ambitious/dont care about the park brake, it would be a relatively simple job to fab up a bracket and pick out an aftermarket(or factory) caliper to bolt/weld on the rear axle.
No, noone just makes a bracket/caliper kit. You wouldnt have a parking brake if you did that. If you were ambitious/dont care about the park brake, it would be a relatively simple job to fab up a bracket and pick out an aftermarket(or factory) caliper to bolt/weld on the rear axle.
If I had an SS in front of me right now I would put em both up and do the research myself. However being deployed in Afghanistan makes that pretty difficult.
EDIT:
I found these pictures off GMpartsdirect.
The hub mounting bolts appear to be the same so that doesnt look to be a problem, but what about the bracket? I couldn't find an illustration for the bracket anywhere on that site.
Also they only listed 2 trailing arms, one with soft ride and one without so I assume the mounting bolts for the hub are identical.
Couldn't I use the rear calipers/brackets from an ss? Unless your saying that the SS calipers/brackets are attached to the SS hubs.
Yes there are basically only 3 total axles. FE1, which is Soft Ride, it uses drums ONLY. Then there is the FE3/FE5 Sport/SSNA/SSSC rear axle which has a larger 22mm sway bar than FE1 and has the disc brake mounting tabs. and then there is the FE5 for the SSTC, its got an even larger 24mm sway bar and again has the disc mounting tabs.
Again, to be clear, without an aftermarket kit, metal fabrication or an SS axle you can not install rear discs on a drum brake car
also something talked about in the ion world is using the rear brakes from an older sc2 as they have the same 4 x 100 lug pattern.. and you could probably yank them form a junk yard.. i dont know all the specifics but i bet you could get it to work somehow
I have seen one, and only one, Z06 go out on the track with the stock brakes. He ended up in the runoff area after losing control in a turn because his brakes weren't just "a little hot".....they were on fire. Yes, they absolutely blow *****.
Oh ok I see it, took me a minute for the 1st pic lol. Thanks again Maven. Something I might be looking into after deployment.
I also see that your sig says you're putting in the FE5 axle. Let me know how that goes and put up a how-to with pix if you dont mind.
I looked up those SSBC kits, they are 12" front and back, not 10" front
they require 17" wheels
do you want rear discs for looks or performance?? I am just mildly upgrading my brakes, slotted discs, SS brake lines, good pads and replacing the old shoes in the rear. I am putting on 8" wide wheels, so more rubber should really help a lot
IDK if that helps your decision or not
and what exaclty blows about the ZO6 brakes?
given I have only punished them on the road and seen no problems, but what are you saying actually leads to there "shittyness"
my dad put on ceramic pads, the originals made an unacceptable amount of dust. they seem to help a lot with dust and a little with performance...a little
Last edited by brandon2.2; Oct 14, 2008 at 09:49 PM. Reason: Automerged Doublepost
