2.2L Rear Disc Brake Conversion?
and what exaclty blows about the ZO6 brakes?
given I have only punished them on the road and seen no problems, but what are you saying actually leads to there "shittyness"
my dad put on ceramic pads, the originals made an unacceptable amount of dust. they seem to help a lot with dust and a little with performance...a little
Now if you REALLY ask them to perform on a road course......they usually catch fire. Pretty much the only time they don't catch fire is if they fail coming up on a turn and you crash.
is everyone missing this ?
Do the old sc2 and the cobalts use the same rear axle setup?
Ya know, I seem to remember making a thread about this stuff... Just last week!
https://www.cobaltss.net/forums/suspension-67/suspension-brake-facts-fe1-fe3-fe5-j41-jm4-jl9-137064/
No, they are ignoring it. Why bother fabricating up brackets just to use old small brakes? If youre gonna fabricate theres no point in going small unless you want to run 15" wheels. No to mention that I think Saturn calipers mount on the opposite side of the axle as Cobalt ones do, so you wouldnt have a parking brake system, If youre gonna give up the park brake youd be MUCH better off buying new aftermarket calipers than using junkyard Saturn bits.
No they dont, old Saturns are not related to Cobalts.
Its not a Delta.
thanks MAVEN and sorry Yelloeye, I guess you can call me Osama thread jacker, JK
I knew that drilled rotors have less surface area obviously, but was not so much aware that they were prone to crack
I think I was blinded by my dad's hype of that ZO6, but I am open to all ideas lol
and when I was talking about those SSBC kits, I meant that you should use both kits front and rear, I just didnt say that, thats where our confusion came in
Its not all hype, the Z06 is an awesome car, and is pretty much untouchable for the price, brakes are just its biggest weakness.
pulling this threat out from the old archives hehehe...
I completed a full conversion, started with rear axle and front hubs from a 2006 SS/NA
I then got new rotors for front & rear, along with new calipers, new E-brake cables, had to change all rubber hoses, so far i'm for about $900
the swap was completed today...we bled all 4 wheels, the pedal is way too low, i tryed driving it around the parking lot, at 10 mph then stomp the brake she wont stop at all, barely slowing her down
any suggestions ?
btw mine is a 2005 Ls none ABS
any suggestions ?
any suggestions ?
any suggestions ?
any suggestions ?
any suggestions ?
too much work...now way! i did this. had brackets made for bolting on the SS calipers from here
OverkillEngineeringMotorsports.com
also in the for sale parts area i have a pair of brakects for sale that work on 4 lug cobalts useing saturn s series rear calipers. it was a pretty easy install
https://www.cobaltss.net/forums/part...ersion-252517/
I'm sure there's gotta be a proportioning valve problem that needs to be solved along with just getting the mechanical swap done. Drum brakes usually have a "residual valve" that keeps about 10 psi in the lines so that the brake pedal doesnt go to the floor.
