2.2L Rear Disc Brake Conversion?
Old Oct 15, 2008 | 01:37 AM
YelloEye's Avatar
I want discs because they are easier to maintain mostly.
Old Oct 15, 2008 | 04:16 AM
mrsilent13's Avatar
Just to let you know ill be buying the ssbc brakes in the near future
Old Oct 15, 2008 | 09:15 AM
alleycat58's Avatar
Originally Posted by brandon2.2
and what exaclty blows about the ZO6 brakes?
given I have only punished them on the road and seen no problems, but what are you saying actually leads to there "shittyness"
my dad put on ceramic pads, the originals made an unacceptable amount of dust. they seem to help a lot with dust and a little with performance...a little
They are for looks only, not for performance, which is pretty much the hallmark of cross-drilled rotors. As soon as you start really pushing the car for anything, even just for an auto-x they will begin to overheat. I've known people who've had them fade just during daily driving from the heat buildup. They just don't have the bite that performance brakes should.
Now if you REALLY ask them to perform on a road course......they usually catch fire. Pretty much the only time they don't catch fire is if they fail coming up on a turn and you crash.
Old Oct 15, 2008 | 09:34 AM
elecblue06's Avatar
Originally Posted by elecblue06
also something talked about in the ion world is using the rear brakes from an older sc2 as they have the same 4 x 100 lug pattern.. and you could probably yank them form a junk yard.. i dont know all the specifics but i bet you could get it to work somehow
is everyone missing this ?
Old Oct 15, 2008 | 10:30 AM
YelloEye's Avatar
Do the old sc2 and the cobalts use the same rear axle setup?
Old Oct 15, 2008 | 10:49 AM
Halfcent's Avatar
I'm old school
Ya know, I seem to remember making a thread about this stuff... Just last week!
https://www.cobaltss.net/forums/suspension-67/suspension-brake-facts-fe1-fe3-fe5-j41-jm4-jl9-137064/
Old Oct 15, 2008 | 11:53 AM
YelloEye's Avatar
Oh thank you halfcent, I completely forgot about that thread. Any idea on the sc2 axle fitting the cobalts?
Old Oct 15, 2008 | 02:01 PM
Halfcent's Avatar
I'm old school
Help me out, "SC2"? I don't know what SC2 is. Is that the Saturn? If so, then it's a Delta car, so the axles should be completely compatible.
Old Oct 15, 2008 | 02:53 PM
YelloEye's Avatar
I was just quoting elecblue06.
Old Oct 15, 2008 | 04:10 PM
Halfcent's Avatar
I'm old school
Ah, okay. I believe the Saturn SC2 was a J-body car, like the Cavaliers. In that case, no, the parts would not be compatible.
Old Oct 15, 2008 | 04:16 PM
  #36
KyleMinnis's Avatar
thats too much work bro...
and too much money...
...i myself have already looked into this, and trust me its not worth it.
Old Oct 15, 2008 | 04:28 PM
  #37
Maven's Avatar
I looked up those SSBC kits, they are 12" front and back, not 10" front
I never said that the SSBC brakes were 10" up front, STOCK 4 lug brakes are 10"
The rotors are drilled which reduces their mass and effectiveness, also makes lots of nice spots for them to crack. The stock pads are crazy expensive and they suck, they dont hold up to repeated hard use well. The calipers are VERY heavy. The system has a very small swept area as compared to other systems with comparable sized rotors.
This is why he doesnt have any concerns with the brakes....becuase hes not driving the car hard....If he was dust would be the least of his worries.
No, they are ignoring it. Why bother fabricating up brackets just to use old small brakes? If youre gonna fabricate theres no point in going small unless you want to run 15" wheels. No to mention that I think Saturn calipers mount on the opposite side of the axle as Cobalt ones do, so you wouldnt have a parking brake system, If youre gonna give up the park brake youd be MUCH better off buying new aftermarket calipers than using junkyard Saturn bits.
No they dont, old Saturns are not related to Cobalts.
Me too.
Its not a Delta.
Old Oct 15, 2008 | 06:08 PM
  #38
brandon2.2's Avatar
thanks MAVEN and sorry Yelloeye, I guess you can call me Osama thread jacker, JK
I knew that drilled rotors have less surface area obviously, but was not so much aware that they were prone to crack
I think I was blinded by my dad's hype of that ZO6, but I am open to all ideas lol
and when I was talking about those SSBC kits, I meant that you should use both kits front and rear, I just didnt say that, thats where our confusion came in
Old Oct 15, 2008 | 07:10 PM
  #39
Maven's Avatar
Its not only that drilling reduces surface area, its the fact that the Z06 has small pads, and a small "swept area" that is the actual amount of area the pads contact the rotor in, Even with the drilled rotors if you switched a different caliper that used a larger pad setup which covered more area on the rotor you could get better braking. Most aftermarket kits that are the same size as the Z06 brakes have MUCH larger pads, and thats one reason they work better.
Its not all hype, the Z06 is an awesome car, and is pretty much untouchable for the price, brakes are just its biggest weakness.
Old Oct 15, 2008 | 09:43 PM
  #40
brandon2.2's Avatar
AND I apologized to yelloeye, my bad the OP is Sarbae
Old Oct 16, 2008 | 08:19 AM
  #41
Sarbae's Avatar
NP man, this is good stuff!
Thanks for the replies guys.
Old May 28, 2011 | 06:12 PM
  #42
twofknloud's Avatar
pulling this threat out from the old archives hehehe...
I completed a full conversion, started with rear axle and front hubs from a 2006 SS/NA
I then got new rotors for front & rear, along with new calipers, new E-brake cables, had to change all rubber hoses, so far i'm for about $900
the swap was completed today...we bled all 4 wheels, the pedal is way too low, i tryed driving it around the parking lot, at 10 mph then stomp the brake she wont stop at all, barely slowing her down
any suggestions ?
btw mine is a 2005 Ls none ABS
Old May 29, 2011 | 02:46 AM
  #43
Maven's Avatar
first thing you need to do is exercise the parking brake. you need to put the park brake on and off a bunch of times to adjust the rear calipers.
Old May 29, 2011 | 08:50 AM
  #44
flyy's Avatar
any suggestions ?
Old May 29, 2011 | 11:46 AM
  #45
YelloEye's Avatar
any suggestions ?
Very nice on the work, but to what end? I can't see any good reason to swap to 5x110
Old Jun 9, 2011 | 05:36 AM
  #46
Lsslowbalt's Avatar
Seems like to much work I might just go ahead and get the ss for this much worry
Old Jun 9, 2011 | 05:42 AM
  #47
BryceL61's Avatar
too much work...now way! i did this. had brackets made for bolting on the SS calipers from here
OverkillEngineeringMotorsports.com
also in the for sale parts area i have a pair of brakects for sale that work on 4 lug cobalts useing saturn s series rear calipers. it was a pretty easy install
Old Jun 9, 2011 | 08:33 AM
  #48
twofknloud's Avatar
$210 for just 2 brackets, got a rear axle with hubs and 2 front hubs for $225 @ a local junk yard
Old Jun 9, 2011 | 05:07 PM
  #49
BryceL61's Avatar
i have the brackets fro sale in my thread for 50 dollers plus ship. i have 5 lug so couldent use those ones had differnt onces made.
https://www.cobaltss.net/forums/part...ersion-252517/
Old Aug 22, 2011 | 03:23 PM
  #50
blackjack hotrods's Avatar
I'm sure there's gotta be a proportioning valve problem that needs to be solved along with just getting the mechanical swap done. Drum brakes usually have a "residual valve" that keeps about 10 psi in the lines so that the brake pedal doesnt go to the floor.
