5 bolt swap question
Old May 2, 2010 | 02:00 PM
WhiteFiver's Avatar
I've got almost everything I need for a 5-bolt swap on a G5 Base (4-lug), but I need a new proportioning valve for the brakes.
I'm looking at an SSBC proportioning valve, but It's going to run me about $85 after tax.
What's a quality alternative?
Old May 2, 2010 | 02:05 PM
09blackonblack's Avatar
you will need 2 for the rear. are you doing the rear disk swap too?
Old May 2, 2010 | 08:58 PM
WhiteFiver's Avatar
I thought the braking system ran through one proportioning valve right off the master cylinder?
And yes, I'm doing rear discs. That's why I need the proportioning valves.
Old May 2, 2010 | 10:10 PM
ok i was making sure you needed the valves... but you need one for each wheel i believe... maven knows more about it than i do.
Old May 5, 2010 | 02:08 AM
WhiteFiver's Avatar
Anybody else? Or should I just start PM'ing the people in the know?
Old May 5, 2010 | 06:47 PM
******************* and ask maven. i have talked to him more than once about this swap. you need 2 valves, the rear brake lines from a ss/sc. and lots of adjusting the valves. UNLESS you have abs but if you have abs you already have 5 lugs
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
