Alginment ? for those with sportlines
I'm FINALLY going to install my sportlines this weekend
I have an alignment scheduled at my dealership for the next morning. This is a question for you guys who have delt with this before: Is the dealer going to be able to do the adjustment correctly with the factorty alignment parts and the sportlines? I wanna know what to tell them if they end up telling me they couldn't do it or couldn't do it correctly? I don't know anything about alignment. Thanks!
it will be fine in fact, if the toe in was correct before it will probably be okay now. Camber and caster is not adjustable, and the slight increase in negative camber you get from lowering the car will not affect anything other than to make the car better in corners. Correcting the bump steer that occurs when you lower the car is simple but not worth discussing if you know nothing about alignment. Make sure your tire pressures are correct and enjoy your dropped ride...
