alignment ?
Old Nov 26, 2008 | 01:43 PM
freakta's Avatar
alignment ?
ok ive got a 2.0 my wifes got the 2.2.
she needs two new front tires and an alignment. is there a difference in the alignment of the two cars. can i get the alignment people to align the car to the specs of mine? just an odd thought i had because her cars tires are bald on the outside, i dont see that very often so i figure more negative camber cant hurt and i know my car has a bit more
Old Nov 26, 2008 | 03:53 PM
Maven's Avatar
The only noticeable difference between the SS/SC and 2.2 alignments is that the SC gets 5/8 degree(.65 actually) more positive caster. The difference in camber is only .05 degrees. Go right ahead and get the 2.2 aligned the same as the 2.0
Old Nov 26, 2008 | 03:57 PM
ls1fbody's Avatar
Haz l33t wheelz.
maven, saving us all from headaches, one post at a time.
Old Nov 26, 2008 | 08:00 PM
qwikredline's Avatar
sure but the reason your wifes car has done that is most likely not enough air in the tires. gotta check it monthly and set it right.
Old Nov 26, 2008 | 08:25 PM
freakta's Avatar
if it was low pressure wouldnt it be bald on the inside and the outside? its just bald on the outside of both front tires, it was just a bit odd to see. and i think i will have it aligned for the ss, it cant hurt haha. thanks for the input
Old Nov 26, 2008 | 10:17 PM
Maven's Avatar
low tire pressure and even semiaggressive driving wears out outside shoulders
Old Nov 27, 2008 | 10:24 AM
Maven its his WIFE. most of the wear affect with low tire pressure is the outer rib rolling over in parking lots and sharp turns etc, so too lo tire pressure. oh and where are my rotors?
Old Nov 27, 2008 | 11:57 AM
Maven's Avatar
Sitting on the shipping clerks desk waiting for Fedex They didnt come on Tuesday OR Wednesday! Sorry for the delay.....
Old Nov 27, 2008 | 02:58 PM
freakta's Avatar
i could see the agressive driving being the culprit... she is an animal behind the wheel
Old Nov 27, 2008 | 09:18 PM
09SS's Avatar
Most of the time if the tire is low on air it will wear the inside and outside edges of the tires.
Old Nov 27, 2008 | 09:22 PM
boostedss26's Avatar
Yes their is a difference between the two. Couldnt tell you what the specs are but if i were at work the alignment machine would tell me
If it were not enough air in the tires it would wear the inside and outside not just one. If their over inflated they wear the middle and leaves the tire cuped
Last edited by boostedss26; Nov 27, 2008 at 09:22 PM. Reason: Automerged Doublepost
Old Nov 27, 2008 | 09:41 PM
thats okay just grinding on ya they aint coming today either (except in Canada Fedex came today, as we had thanksgiving in October, as the pilgrims came here first...then of course went south....snowbird pilgrims) So thanksgiving in the usa is in November....
just to be stubborn of course it does, but more outside than inside due to FWD, scrub radius and the Macpherson strut suspension etc.
Last edited by qwikredline; Nov 27, 2008 at 09:41 PM. Reason: Automerged Doublepost
TotalChaos
Oct 14, 2015 06:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
ROADKONE
Sep 9, 2015 02:32 PM
DisJuan
Sep 7, 2015 04:24 PM
