Alignment only?
Alignment only?
I know this has been mentioned before, And I DID search and read the sticky, but the information isnt concrete for me yet.
I have a 2006 SS/SC, If i purchase Eibach sportlines springs and Install them myself, all i need is an alignment once I am done?? No camber kits right?
Also, With the spring and an immediate alignment, Will my tires wear evenly?
Any help would be great! Thanks guys!
UMMMM, i have sportlines on my car now and i have not needed an alignment and everything works great. No uneven wear and no camber kit needed. Everything dropped great. I have stage 2 on my ss/sc as well (not that it has anything to do with anything, lol). Anyway, you should be fine, but you can get an alignment if you want that extra bit of protection.
and remember, they're girls on this site as well.... so you gotta says guys and gals!!!!
It will be in your best interest to atleast have the alignment checked after your install. there is almost no 100% chance of not needing an alignment after any type of suspension work. I'm not saying get the alignment done, just have it measured and evaluated to see if there is adjustments needed. Better safe then sorry.
The rule is get an alignment but not immediately. Let the springs settle for a week or so that way the car is closer to its actual ride height when you get the alignment. Everything should be fine but it may not. Only other way to know is to let your tires get trashed. I know I have a specific advantage because I have access to an alignment machine, but its just good insurance.
DANRICKARD
Oct 1, 2015 12:08 AM
