Alignment only?
Old Jan 27, 2008 | 10:28 PM
effex80's Avatar
Alignment only?
I know this has been mentioned before, And I DID search and read the sticky, but the information isnt concrete for me yet.
I have a 2006 SS/SC, If i purchase Eibach sportlines springs and Install them myself, all i need is an alignment once I am done?? No camber kits right?
Also, With the spring and an immediate alignment, Will my tires wear evenly?
Any help would be great! Thanks guys!
Old Jan 27, 2008 | 10:32 PM
DebadgedBALT77's Avatar
no camber kit needed. I just did mine, ( 06 LS ) and only adjusted amber and toe, toe was out due to other reasons though.
Old Jan 27, 2008 | 10:35 PM
devon9832's Avatar
UMMMM, i have sportlines on my car now and i have not needed an alignment and everything works great. No uneven wear and no camber kit needed. Everything dropped great. I have stage 2 on my ss/sc as well (not that it has anything to do with anything, lol). Anyway, you should be fine, but you can get an alignment if you want that extra bit of protection.
and remember, they're girls on this site as well.... so you gotta says guys and gals!!!!
quadracer0387's Avatar
i installed mine myself and went to get an alignment and it was already perfect.. but your tires should wear perfectly if you had it aligned. no other kit is needed
Old Jan 27, 2008 | 10:36 PM
stealthy1ss's Avatar
Get an alignment and you should be set.
CinciSS07's Avatar
i have my car dropped on tenzos and when they did my alignment it was already perfect
Old Jan 27, 2008 | 11:19 PM
effex80's Avatar
awesome! Its helps a ton guys and gals! lol
Old Jan 29, 2008 | 11:04 AM
myoshizawa819's Avatar
Yeah, I self installed my Sportlines and my alignment was fine after the drop, no adjustment required.
Old Jan 29, 2008 | 11:13 AM
Dead Zen's Avatar
indeed. i am dropped on sportlines and the shop said the alignment was perfect afterwards
Old Jan 29, 2008 | 06:19 PM
06blackSC's Avatar
It will be in your best interest to atleast have the alignment checked after your install. there is almost no 100% chance of not needing an alignment after any type of suspension work. I'm not saying get the alignment done, just have it measured and evaluated to see if there is adjustments needed. Better safe then sorry.
Old Jan 29, 2008 | 06:33 PM
CTORANGESC's Avatar
I have personally lowered 5 or 6 Balts and did alignments on all of then and so far, Not one of them has been out of alignment. But, I still do strongly suggest you do it, It couldnt hurt
Old Jan 29, 2008 | 07:31 PM
montecarloman's Avatar
The rule is get an alignment but not immediately. Let the springs settle for a week or so that way the car is closer to its actual ride height when you get the alignment. Everything should be fine but it may not. Only other way to know is to let your tires get trashed. I know I have a specific advantage because I have access to an alignment machine, but its just good insurance.
Old Jan 29, 2008 | 07:37 PM
rallyracer's Avatar
The the Eibach Sportlines springs all I need was an alignment. I waited 2 weeks to get the alignment to allow the springs to set in.
TotalChaos
Oct 14, 2015 06:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
ROADKONE
Sep 9, 2015 02:32 PM
DisJuan
Sep 7, 2015 04:24 PM
