Alignments
Alignments
I need to get one soon... what is the stock alignment for an SS/TC? autox? track?
is camber adjustable on these cars at all stock? I would imagine i should run as much as i can get right? and how much toe? zero or a hair of toe out?
Camber isn't really adjustable stock, unless you grind the holes in the struts. You'll have to use camber bolts to adjust it. You can probably happily get away with zero toe. For the very aggressive, I would toe it out, but this will wear the tires quicker. -.2 degrees per wheels on an 18" wheel will get you 1/16 total toe out.
For camber? As much as you can get. I run -2.3*. Could probably use more, but this is sort of a compromise.
Forget about rear settings. They can't easily be adjusted.
What is the main function of your car?
For autox I run -2* camber up front with *.5 toe out for better turn in. Rear specs are stock.
And no camber is not adjustable stock, you need either eccentric bolts or the "strut mod" and drill out the top strut to knuckle bolt hole to gain negative camber. For the rear you need to shim to hubs, I would not do this though as I don't think the rear needs camber.
edit: sorry wang basically covered everything.
the car is my daily driver but i tend to maintain my cruising speed thru corners... It looks as tho the pedders added a little bit of neg camber. so basically just get the toe zero'd out?
If you don't care about sticking to DStock rules, which you don't, given the Pedders, I would just get a set of camber bolts, and at least give yourself a little more there. You can keep it more mild, like -1.5.
I ended up with -0.5 on the back with my Pedders coilovers. I thought you had a set too for some reason.
DANRICKARD
Oct 1, 2015 12:08 AM
