Any way to fix axle bind?
Old Dec 22, 2011 | 08:41 PM
07cobalt2.2's Avatar
Is there any way to fix axle bind? or is it something you just have to live with, I'm only lowered on H&R springs. no other suspension mods.
Old Dec 22, 2011 | 08:47 PM
EXsoccer1921's Avatar
tc axles and hub swap
Old Dec 22, 2011 | 10:15 PM
Sharkey's Avatar
will the tc axles stop the binding from the extreme driveline angle?
im on the same springs and ive had my share of issues. i ended up taking out both axles, and ive been struggling with vibrations since i bought my car. powell rotated mounts do help a lot, but i still have vibrations i cant get rid of, and i know its being caused by the driveline angle. ive looked at it a bunch, and aside from further rotating the motor forward, or lifting it up (either way, lots of custom work), the only way to fix it is raise the car up with less agressive lowering springs.
Old Dec 22, 2011 | 10:17 PM
bri2203's Avatar
I have a set of TC spindles if you decide to upgrade.
Old Dec 22, 2011 | 10:19 PM
when will was still on the lsj axles with his car slammed down, he got bind like no other. when he did the hub swap to 5x114.3 he decided to go with tc axles. and bind went byebye.
when i said tc axles and hub swap in my 1st post i don't mean a 114.3 swap. but you will need lnf hubs along with the axles
Old Dec 23, 2011 | 11:14 AM
bri2203's Avatar
Sounds like you are refering to the spindle/ knuckle.
Old Dec 23, 2011 | 04:52 PM
no the hub itself. the input shaft on the tc axle going to the hub is larger than the lsj iirc. along with the axle shaft itself
Old Dec 23, 2011 | 05:04 PM
sick CCSS's Avatar
may be a dumb Q but i have a lsj, not lowered or anyhting and i get a click when i start out or go to back up, just one click from a dead stop either way. sound slike both sides, is this axle bind?
Old Dec 23, 2011 | 06:02 PM
Sharkey's Avatar
no that isnt axle bind. axle bind happens when you near the maximum angle the cv axle can go, and it generally causes a vibration. a click noise when first starting out could be a number of things, could be a bad axle, could be a mount, could even be the flex pipe on the exhaust.
Old Dec 23, 2011 | 06:30 PM
drumrush's Avatar
Is there anything to do for a base model with 4 lugs?
Old Feb 7, 2012 | 10:39 AM
breds2k's Avatar
bump, when i start off it feels like im going over uneven pavement for a second, not violent just a bit of "wobble" in the front end. no problems turning.
2007 LS on megans, stock struts.
is this axle bind?
Old Feb 7, 2012 | 11:33 AM
BLKLS's Avatar
I heard recently about some VW guys that take the CV joint apart tim a few millimeters off the axles and put them back together. Not saying it's the best option but...
Old Feb 7, 2012 | 11:38 AM
BLAZIN07SS's Avatar
I'm too JDM for you
it's not the lnf axles and hubs that fixes the axle bind. powells rotated mounts essentially kill all the axle bind. i'm slammed and i barely have any bind. i will be making a shorter axle shaft so that the axles are not at such a severe angle. then it won't bind at all
Old Feb 7, 2012 | 12:08 PM
drumrush's Avatar
Too bad I have an auto then
Old Feb 7, 2012 | 02:16 PM
I fixed my axel bind!!!
I put the stock springs on my car.
Old Feb 7, 2012 | 02:56 PM
cleanxfe's Avatar
is this axle bind?
i heard rack spacers fix that
Old Feb 7, 2012 | 03:25 PM
breds2k's Avatar
^I heard that Vin Diesel is a homosexual but not sure if its true.
Anyone know any true fix to this if it is in fact axle bind? And are my axles going to go bad over time?
Old Feb 7, 2012 | 03:50 PM
yes, your axels are going to have a shorter life.
Old Feb 7, 2012 | 08:55 PM
BLKLS's Avatar
Rofl!!!!!! Yes!!
biniecki
Oct 25, 2015 02:23 PM
dieGone
Oct 1, 2015 06:27 PM
DANRICKARD
Oct 1, 2015 12:08 AM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
