Anyon who upgradedstruts or has coilovers
I had a little suspension issue, and need a new lower strut mount for the front struts. GM only sells it as a unit with the strut included, and I dont need all that. Let me know what you guys got, because time is a factor. Thanks guys
http://www.trademotion.com/schematics/C/CL05260.gif
its part #7
its part #7
Did you install your koni shocks? That is one whole peice that you had to cut apart to put koni's in koni's are inserts not full struts. You can only order them as a whole strut anywhere, junk yard or someone selling the whole strut may be able to help but otherwise you'll have to buy the whole strut. Cheaper option for new KYB gr2 struts? No matter what in order to put your koni in you need to cut the strut apart!
