AutoX with Stance GR+??
Old Jul 8, 2012 | 02:00 PM
jzehren11's Avatar
So I still cant decided which coils to go with. Stance or KWv2
I want to go low, but I also want to be able to AutoX with them without having to worry about bustin ****.
So has anyone AutoXed with Stnace GR+? and if so how did it go?
Old Jul 8, 2012 | 02:03 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Nathan Benton does auto x with stance
Old Jul 8, 2012 | 02:30 PM
noorj's Avatar
They wouldn't break. They won't be the best at all, probably worse than your stock suspension.
Old Jul 8, 2012 | 02:35 PM
jzehren11's Avatar
so really I am probably better off with KW
Old Jul 8, 2012 | 02:50 PM
TommyP's Avatar
AWD > FWD
Yes, the KWs will handle better, though both could be greatly improved with some stiffer springs.
Old Jul 8, 2012 | 02:51 PM
jzehren11's Avatar
and what would you recommend as far as better springs?
Old Jul 8, 2012 | 04:09 PM
noorj's Avatar
Swift Springs
Swift Springs USA
Not quite positive on what rates. Possibly 8k front 10k rear depending on what rear bar you use, but I'm not sure. You'll have to ask pros. But I would also suggest KW V2's if you can swing the cash, well worth it over the Stance's because you can still go plenty low.
Old Jul 8, 2012 | 04:26 PM
TommyP's Avatar
AWD > FWD
swift springs makes good stuff. What you want is stiffer springs in the rear than front. Those coilovers will come the other way around, and you want the rear to be stiffer to help combat understeer.
Old Jul 8, 2012 | 06:29 PM
1LSJ2NV's Avatar
Cobalt Nation
Ive yet break anything and I beat the **** out of my car. Ive only AutoX'd once but I hear KW's are very good.
Old Jul 8, 2012 | 06:39 PM
09sscalicobalt's Avatar
KWV2S if you want coilovers but best bang for your buck if you dont care about going low is koni yellow/pedders springs
and you would still have money to buy some CABS or a rear sway bar too
OrangeCoba
Oct 1, 2015 10:00 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
