AutoX with Stance GR+??
So I still cant decided which coils to go with. Stance or KWv2
I want to go low, but I also want to be able to AutoX with them without having to worry about bustin ****.
So has anyone AutoXed with Stnace GR+? and if so how did it go?
Swift Springs
Swift Springs USA
Not quite positive on what rates. Possibly 8k front 10k rear depending on what rear bar you use, but I'm not sure. You'll have to ask pros. But I would also suggest KW V2's if you can swing the cash, well worth it over the Stance's because you can still go plenty low.
Swift Springs USA
swift springs makes good stuff. What you want is stiffer springs in the rear than front. Those coilovers will come the other way around, and you want the rear to be stiffer to help combat understeer.
KWV2S if you want coilovers but best bang for your buck if you dont care about going low is koni yellow/pedders springs
and you would still have money to buy some CABS or a rear sway bar too
