Baer brakes
Old Sep 19, 2006 | 12:16 PM
DWK5150's Avatar
Baer brakes
Gravana has Baer brakes now listed on there web site.
http://www.gravanatuning.com/applica...r_Track_Brakes
Old Sep 19, 2006 | 12:18 PM
Sp00ner's Avatar
Would love to see some test data... SSBC wouldn't provide any... hopefully Baer will be better...
Old Sep 19, 2006 | 12:20 PM
DWK5150's Avatar
Yeah that would be great.
Old Sep 19, 2006 | 03:56 PM
DPF's Avatar
DPF
rk sport has that same system for much cheaper
Old Sep 19, 2006 | 05:59 PM
SS_SC_Cobalt's Avatar
take it from someone that has used baer before several times, it is top notch!
Old Sep 19, 2006 | 06:01 PM
ggarcia86's Avatar
i think i'm gonna go with power slots for the bargin, i'll be happy as long as they dont warp as fast as the stockers
Old Sep 19, 2006 | 06:17 PM
DPF's Avatar
DPF
accually i think the baer brakes are cheaper than the ssbc. download the rksport catolog thats where youll find them
Old Sep 19, 2006 | 06:21 PM
p7x's Avatar
p7x
SICK baer is some badass ****!
Old Sep 19, 2006 | 07:03 PM
05OrangeSS's Avatar
The SSBC kit is actually cheaper, well the front is. I don't know about the rear. If those are the exact calipers they look REALLY similar to stock Cobra fronts. If you want info on the SSBC kit just let me know. Ill use someones G-tech for 60-0 info. Ill say this though, they definately don't fade as fast as the stockers do.
Old Sep 19, 2006 | 07:43 PM
Sp00ner's Avatar
I requested that info from you quite some time ago and never heard from you again about the subject...
Old Sep 19, 2006 | 07:46 PM
Ljavy17's Avatar
I love the Baer, Finally a set I can vouch for.
Old Sep 19, 2006 | 08:31 PM
05OrangeSS's Avatar
crap, sorry about that. Ill see what I can do by friday sometime. Friday is my day off so hopefully I can get it done by then. Either way upgrading your factory disc brakes really doesn't make THAT much of a difference, unless your going from like a 2 piston kit to an 8 piston kit. The kits offered for our cars REALLY won't make THAT much of a difference. Although if your looking for that "bigger rotor" Baer's is .8 inches bigger than the SSBC kit.
Old Sep 20, 2006 | 12:08 AM
Serpico's Avatar
available with aluminum hats ???
Old Sep 20, 2006 | 01:05 AM
05OrangeSS's Avatar
Makes it lighter than having a 1 piece all steel rotor. The "hat" is aluminum just for less weight, that's pretty much the only reason.
Old Sep 20, 2006 | 01:45 PM
Serpico's Avatar
lol i know what they are im asking if they are available with aluminum hats...was wondering if gravana was watching this thread and possibly provide an answer
the aluminum also has a beneficial effect on cooling
Old Sep 20, 2006 | 01:50 PM
you would have to upgrade to eradispeed rotors...$200 a piece
Also there are 2 reasons to go 2 pce, rebuilding the rotors with a new ring if you wear them out, weight and durability
Old Sep 20, 2006 | 01:53 PM
cawpin's Avatar
An aluminum center section won't help with cooling. You want heat to go away from the center.
Old Sep 20, 2006 | 04:00 PM
Serpico's Avatar
not according to baer
http://www.baer.com/Products/Complet...ems/Track.html
<-----TRACK-PLUS
The Baer Claw® TRACK-PLUS is hands down Baer's most popular system for street and light-track applications. Two-piston aluminum calipers are coupled with 2-piece, 13" rotors, taking the performance of the Baer Claw TRACK system to the next level! The secret is the 2-piece rotor design, which uses an aluminum hat to reduce overall weight. This design also allows for differential expansion of the rotor plates, reducing the "bell effect," lowering thermal transfer to the hub, and ultimately prolonging bearing life. May fit some 16" wheels. Check wheel fitment with Baer fit check templates.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
