Best coilovers?
this is what i was told
"The valving is bad, the spring rates are bad, the adjustment is poor, overall build quality is bad for a good handling setup. A good handling set of coilovers on any car is gonna cost at least $2k+. If you want the best handling setup, get a set of Pedders springs, and Powell XXX rear sway bar. Talk to wangspeed, he tracks his car quite often. I believe his setup right now is pedders, xxx, and Koni adjustable rear shocks. A good set of tires such as dunlop star specs or bridgestone RE-11s will make just as much of a difference as springs."
maybe i will just do that this weekend
