Beware of your Brakes!!!!!
I pulled my front calipers off the car tonight and the driver's side outer brake pad had split in two!!! The brake pad had slid down and was rubbing the neck of the rotor, causing irregular wear and irregular braking I am sure. Be forewarned!!!! Check your car out, you don't have to pull the caliper just look at it. Better safe than sorry!
You can see the uneven wear of the pad in this picture.
