Big Brake Kit New Product Interest
Old Apr 25, 2008 | 11:19 PM
TurboTechRacing's Avatar
Who would be intersted in a big brake kit for the front and rear SS Cobalt?
What we are thinking of is offering a 2 piece rotor/hat assembly, and manufacturing a "bracket" to re locate the OEM caliper "outward" So we would offer a larger diameter rotor assembly, with the OEM caliper relocated.
Price would be between a replacement set of rotors, and the full all out, SSBC or Baer Brake kit...
Power Slot and other manufatures offer this for some other models, like the Mitsubishi Eclipse. We would be the manufacture and do the design, testing, and manufacturing....
What are your thoughts?
Old Apr 25, 2008 | 11:21 PM
jimbos'ss's Avatar
in the future i would, i definately wanna upgrade the brakes on this car as it gets more road coarse time
fballman1987's Avatar
would this work with the stock 18's or would we need to go bigger?
Old Apr 25, 2008 | 11:23 PM
blk ss/sc 1's Avatar
i dont see why we would have to go bigger then 18's... but anyway im definately interested but not for like $900 for each set...
Old Apr 25, 2008 | 11:36 PM
We are thinking AROUND $400-500 per axle for the rotor, hat, calaiper re location bracket, hardware, etc... With this setup you would still use any aftermarket brake pad you would like (HAWK, EBC, ETC)
We will also design them to work 100% with the stock OEM rims.
Old Apr 25, 2008 | 11:39 PM
Raven SS's Avatar
so the caliper would still grab the same amount of brake rotor?
Old Apr 25, 2008 | 11:41 PM
jimbos'ss's Avatar
so basically about a grand for the whole front setup, sounds like a sweet deal to me, will it work with the abs?
true, but with the larger radius rotor it will take less pressure to do the same amount of braking.
Old Apr 25, 2008 | 11:44 PM
DoubleLP's Avatar
I would be interested down the road. MAKE SURE though that it will fit with a 16" steelie rim so those of us who have to put winter tires on will NOT have any clearance issues.
Old Apr 25, 2008 | 11:48 PM
Smitty1017's Avatar
I wonder how much gm will charge to just buy the brembos off of the ss/tc?
Old Apr 26, 2008 | 12:21 AM
x2.. but i dont think thats goin to be possible... 4-500 is a good price though
Old Apr 26, 2008 | 12:24 AM
Scythe_Snake's Avatar
OMG!!!! PLEASE do this. I go to shows and see these other cars with these HUGE cross drilled slotted rotors and calipers. I won't it so much.
PS what about your guys 4-2-1 headers? :P
But yeah...this:
cross drilled AND slotted with color choices for calipers and HUGE calipers....mmm.
Make them look good with larger wheels and better than the SS/TC brakes.
Old Apr 26, 2008 | 12:36 AM
jimbos'ss's Avatar
i'll bet they are gonna be expensive as hell, i'll go with aftermarket.
Old Apr 26, 2008 | 09:04 AM
Yes, most "big brake kits" do have the same amount of surface, what they do is offer a further out distance of "grabbing" acting as a larger "lever arm" kinda like using a wrench, using a 6" vs a 12" the 12" you can get much more force on the nut you are torqing... I hope this makes sence...
We are actually looking at Brembo rotors (slotted and drilled), and machining our own "hats" and "brackets" for the kit...
Last edited by TurboTechRacing; Apr 26, 2008 at 09:04 AM. Reason: Automerged Doublepost
Old Apr 26, 2008 | 09:12 AM
Death Dealer's Avatar
So will this be $1000 for the front and $1000 for the back. You said the Calipers would be from Baer?
Old Apr 26, 2008 | 09:14 AM
steddy2112's Avatar
What about us lowly SS/NAs.
I run 18s in the summer but in the winter my stockers go back on.
Plus would we have to get terra-bad drilled and slotted or could we get 'blanks' because we like to stop fast?
MMMmmmm brake fade go
Old Apr 26, 2008 | 09:16 AM
No, it would be around $1000 for the front and rear. The calipers are the OEM ones just relocated "outward"
We could do this same upgrade for the 4 lug, NA 2.2L setups also (fronts only) as the rears are drums.
Last edited by TurboTechRacing; Apr 26, 2008 at 09:16 AM. Reason: Automerged Doublepost
Old Apr 26, 2008 | 09:19 AM
steddy2112's Avatar
Would said big brake kit fit with the SS/NAs 17s.
Would we have a choice in brake rotors?
I guess I can be confusing when being goofy.
Old Apr 26, 2008 | 09:24 AM
We would offer 1 rotor set, you would not have a choice at this time. Whatever we do chooce I am sure everyone will be very happy
Old Apr 26, 2008 | 09:25 AM
steddy2112's Avatar
Wouldn't mess with the ABS at all?
Plus how much heavier you think they would be over stock?
Old Apr 26, 2008 | 09:35 AM
BRN169's Avatar
I just wish someone would produce a true four piston Brembo upgrade for the front AND rear. I got all happy when I found out GM was offering Brembos on the '08 TC only to find out they are only on the front... Kinda stupid in my opinion to got half way... The CA Z06 upgrade is cool but WTF w/no E-brake? I am probably going to break down and buy the Baer kits but I would much rather have Brembos...
Old Apr 26, 2008 | 09:37 AM
steddy2112's Avatar
80% of your braking is done with the fronts and a big torque brake in the rear means easier rear lock up.
Rear lock up under heavy braking is the reason why ABS exists on cars...because it sucks.
The problem with big cool looking brakes is you are sacrificing safety if they are not set up properly.
Old Apr 27, 2008 | 11:13 AM
BRN169's Avatar
That is why God invented proportioning valves
I found a cool solution to the CA Z06 brake kit problem...
http://www.raceindustry.com/part-sho...brake-kit.html
Old Apr 27, 2008 | 11:25 AM
REDFOCZ's Avatar
Can you do anything for us four lug guys?
Old Apr 27, 2008 | 11:29 AM
originaladrian's Avatar
read thru the thread
Old Apr 27, 2008 | 11:42 AM
REDFOCZ's Avatar
Reading > Me
This is what I get for just reading the first three post lol
