Big Brakes
Old Jul 9, 2009 | 05:45 PM
XTC_916's Avatar
Big Brakes
When I see sport cars like the corvette with huge rotors and brake calibers I envy them. What company sells big brake kits for our cars? I know JBP has a big brake kit but its off the charts to expensive. So where can I get these Monster rotors, brake calibers, pads, hose lines the whole deal?
Old Jul 9, 2009 | 05:47 PM
cobalt123's Avatar
what model car are you talking about: l61? thats what im assuming the brembos are pretty solid
Old Jul 9, 2009 | 05:51 PM
XTC_916's Avatar
The LSJ
Old Jul 9, 2009 | 06:16 PM
constantproject's Avatar
this looks drilled for the 4 lug too...!?!? i want if it is, neone know for sure?
Old Jul 12, 2009 | 04:00 PM
nickr's Avatar
Get the TC brembo's =]
Old Jul 12, 2009 | 07:09 PM
qwikredline's Avatar
diamters are 312 for LSJ or 315 mm for TC is as big as it gets, x 28 mm. floating from OTTP. The vette has 355 mm and you can buy 380 mm rotors That sort of swept area cannot be packaged and made to work within the hydraulic system of the Delta cars
Old Jul 12, 2009 | 07:13 PM
312 x 28 mm for lsj 315 x 28 for TC floating rotors and BBK for LSJ from OTT is as good as it gets the hydraulic system and the wheels/brake balance issue cant handle bigger...
Old Jul 12, 2009 | 07:14 PM
Old Jul 12, 2009 | 07:22 PM
Old Jul 12, 2009 | 07:29 PM
ls1fbody's Avatar
Haz l33t wheelz.
wow john, relax, haha
now, any idea why my brake pedal feels soft?
Old Jul 12, 2009 | 07:30 PM
exiged's Avatar
try bleeding your lines.
Old Jul 12, 2009 | 07:31 PM
air. bleed left rear right front right rear left front. bleed front calipers outside bleeder then inside bleeder. look for leaks. You got new crush washers, new seals, you got air somewhere....O and the more you f**k with it the softer it gets
Old Jul 12, 2009 | 07:32 PM
ls1fbody's Avatar
Haz l33t wheelz.
duh. They're bled. Trust me, nothing but clean fluid comes out of the lines, i was wondering more along the lines of the master cylinder size being different, or if i need to bleed up by the clutch as well.
oh and the mutliple posts are caused by a database error on the nub.net server grrrrrrr
Old Jul 12, 2009 | 07:36 PM
ls1fbody's Avatar
Haz l33t wheelz.
yeah, just did it to me. 30 seconds between posts? WTF? Jonel needs to use the premium member fees to actually improve the site.
Old Jul 12, 2009 | 07:38 PM
duh apparently not trust me. I got the same stuff ROCK SOLID BRO'. I love them and the new floating rotor is KICKASS...damn now i gotta put the TVS on so I can use these brakes...yes tested from 230 k/hr
Old Jul 12, 2009 | 07:44 PM
ls1fbody's Avatar
Haz l33t wheelz.
where's my floating rotors? huh?
haha, ok, well, they were gushing pure fluid, everything is topped off...
now, i also have an ABS light, but HPT won't pull a code, any idea if they're connected?
Old Jul 12, 2009 | 09:28 PM
for the soft pedal you may need to do an abs bleed its not usually needed but i dont know how far apart your car has been dismantled, you need a tech 2 to do it better fly maven out and get it all done at once...the codes make no sense unless your connectors are not done up. I have the same front bearings you have its 100% and ditto on all grand am cobalts and you dont have an 07 so .....tech 2 scan will tell you where the abs fault is. I did rotate the rear caliper pistons back to accomodate new pads, so you may need to ratchet the hand brake a few times to get the rear pads up tite, if they are not you can have a spongy pedal change to email or sites for more
Old Jul 13, 2009 | 03:08 PM
harryresh's Avatar
Cobalt Addiction sells big brake kits too. I find these guys to be much more expensive though.
Old Jul 13, 2009 | 05:16 PM
Halfcent's Avatar
I'm old school
Ssbc
Old Jul 13, 2009 | 05:18 PM
badg1rl's Avatar
we sell a z06 brake conversion kit
Old Jul 13, 2009 | 07:34 PM
Stiner's Avatar
do you want them for the look or function?
06MetallicBalt
Jul 20, 2025 08:47 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
