big problem
Old Sep 4, 2007 | 04:53 PM
DoNtGeTdUnNuP's Avatar
big problem
i installed sportlines on my ls last night and this morning i went to drive it for the first time and bad news for me. at the slightest bump the rear clunks pretty loud. something is wrong back there and i dont know what it is. i took it to les schwab and they said it wasnt a clearance issue nor anything wrong with wheels or tires. they said its prolly my springs. sounds like metal to metal clunking. what could it be?
Old Sep 4, 2007 | 08:08 PM
bluebaltjim's Avatar
probly loose rear shock bolts, you have to tighten the crap out of them. if you're using a socket use a cheater bar, if an air gun turn the pressure up all the way. when i installed my koni's i had the same sound, very heavy metal on metal, i got like 1/2 turn out of the right rear and the noise went away.
Old Sep 4, 2007 | 09:58 PM
just found out what it was.. had to the wheel off to see and push down on the car. when i got my exhaust done they ran the pipe too low for lowering the car.. so when i hit a bump the thing that holds the bottom of the spring hits the exhaust pipe.
06MetallicBalt
Jul 20, 2025 08:47 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
