Bounce after lowering?
So, I just installed some Ksports today. I love the look, but they are BOUNCY! Is some of that from having the wrong length sway bar endlinks? I know when I lifted my older Tacoma, I had the same problem because the sway bar links were not long enough.
How do you have them adjusted? You can stiffen the shock by twisting the knob at the top of the strut. That should make it a lot less bouncy to bone jarring stiff.
Those springs may just be softer springs than stock. Sportlines definitely are and bounce more.
Ahh I saw Ksport and just assumed they were the coilovers. I will assume you installed them on stock shocks, and so with a stiffer spring than the stock FE1 spring, your shocks cannot handle the higher spring rate. You may notice a bit less bounce with powergrid end links but most likely not.
u actually might be more bouncy cuz you bought the wrong swaybar endlinks?? i just did lowering springs on my car and replaced the endlinks to a better brand, but they are the sway size, just an easier one to work with, so that actually might be ur problem, cuz obviously ur gunna bounce a little more with lowering springs, but it shouldnt be toooo much more
Okay, they are Ksports on KYBs. I have the stock FE1 endlinks. I know they are WAY too long. I disconnected them, and it was better. It's still bouncy (I mean, it is a LOWered car), but not quite as bad. So, I guess rotated trans mounts and endlinks are in my near future. Where are you guys buying endlinks from?
http://cgi.ebay.com/ebaymotors/05-09...Q5fAccessories
Moog FE5s compared to GM FE3's
hes right. cheap spring+crap rates=bounce and harsh ride. you dont need to be a baller and spend the money on coilovers. pedders on fe5 struts would have a been a great idea.
almost all lowering springs minus the eibach pro kit and pedders have nasty coilbind.
yep^
^^are you just putting that to compare? i owuldnt recommend the pro kit theres absolutely no drop on them what so ever. pedders have better rates for the fe5 struts. best lowering springs out for fe5 struts period.
Um, I live in the desert, nothing rusts here, lol.
And there is a bit of lowering. And I didnt buy it for the lowering I bought it for the performance. The pro kit handles better than the sportlines. It lowered my rear down close to .7 now. The front it said it wouldnt but im now at .2 inches lower. But like I said I bought it for the handling.
I put it up because of the coil bind talk.
