Brake Fluid?
Old Mar 10, 2010 | 08:49 PM
insylem's Avatar
Question Brake Fluid?
Is all brake fluid the same?
DO we need synthetic brake fluid for our cars? What kinddo we put in? The manual just says DOT 3. Is that Conventional? Synthetic? What happens if I mix. I baught my car used, dont know whats it in now.
Old Mar 11, 2010 | 12:06 PM
08SSTCRD's Avatar
All brake fluid is technically "synthetic", so it really doesn't matter either way what the bottle says.
Your best bet is to get a good brand name DOT4 fluid. DOT3 and DOT4 are 100% compatible, DOT4 just has a higher boiling point, which is beneficial.
Valvoline makes one that says "Synthetic DOT3/4 Brake fluid" which is good.
I use ATE Super Blue DOT4 in my other car, which one of the best brake fluids you can buy.
Old Mar 11, 2010 | 12:09 PM
Stiner's Avatar
for the most part it's all the same just try to keep it fresh is the main part
Old Mar 11, 2010 | 09:03 PM
Wangspeed's Avatar
If it's not seeing track duty, Valvoline Synthetic is a decent one that you can find at any parts store.
Old Mar 11, 2010 | 09:04 PM
PRND3L's Avatar
any DOT 3 or DOT 4 will work
Old Mar 11, 2010 | 09:19 PM
rallyracer's Avatar
How about if I am seeing some track duty?
Is there one that'll work great for track, daily driver and in while driving in the winter?
Old Mar 11, 2010 | 10:59 PM
08SSTCRD's Avatar
ATE Super Blue DOT4 will suit that purpose very well.
Your best bet is to order it online, its unlikely that you'll find it in any parts stores.
Old Mar 12, 2010 | 04:40 AM
Wangspeed's Avatar
The Valvoline is actually pretty good, and will hold up at the track if you're not too hard on brakes. ATE is a little better. My favorite is Neo 610, which is a bit hard to find, but great stuff. Castrol SRF is the king of all brake fluid. Really is in a class of its own, but it's also in a price range of its own.
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
