brake help
Old May 29, 2009 | 12:27 AM
evZO6's Avatar
brake help
I have an 07 LT and im looking to upgrade the front brakes i was thinking about going with powerslots and hawk pads, but my car has a 5 lug patter. I did some searching and i cant seem to find if powerslot or and quality makes oem replacement rotors for the 5 lug pattern that isnt an ss.
Old May 29, 2009 | 09:31 AM
Johnboy12358's Avatar
you have an LT with 5 lugs?? Would the SS/SC rotors fit?
I didnt know they made LTs with 5 lug wheels... maybe I just dont pay attention
Old May 29, 2009 | 09:36 AM
YelloEye's Avatar
They do make 5 lug non SS balts, not sure what year that happened but it did happen at some point. It makes me wonder if the front brake rotors are the same size as they are on an SS.....
Old May 29, 2009 | 09:44 AM
Yeah, I would check the measurements, and if they are the same just get some SS/SC powerslots.
Old May 29, 2009 | 01:28 PM
evZO6's Avatar
Im at work right but I will check that out tonight thanks
Old May 29, 2009 | 11:20 PM
YelloEye's Avatar
Or check the part numbers for the OEM parts at either your local dealership or at gmpartsdirect.com
Old May 29, 2009 | 11:57 PM
SkateKrooked's Avatar
im looking for the same thing on my lt.
i think on the 07 l models they started doing 5 lug.
Old May 30, 2009 | 09:14 PM
speedracer2009's Avatar
these are the rotors and pads i have on my 08 balt LT u can convert the rear drums to rotors if u want to http://www.crateenginedepot.com/stor...arts-C192.aspx
Old May 31, 2009 | 01:16 AM
Maven's Avatar
5 lug LTs and 2009 G5GTs have a 280mm front rotor, its NOT the same as any SS model or any other current car. AFAIK there is currently no upgraded rotor available for the cars.
Old May 31, 2009 | 04:46 PM
Listen to this man, he knows what the hell he is talking about.
Old Jun 17, 2009 | 03:59 PM
evZO6's Avatar
Thanks i know that the 08 and 09 have 5 lugs would brakes for that year car fit mine.
Old Jun 17, 2009 | 11:59 PM
Maven's Avatar
Yes they will, problem is that afaik no no one makes an upgrade aftermarket rotor for the 280mm cars yet. Its gonna be pretty much GM or basic parts store stuff.
Old Jun 18, 2009 | 09:33 AM
evZO6's Avatar
I took a look at the sticky about the all the suspension and brake stuff and it looks like i have the same 276 mm rotors that come on later cars. At least thats the way it looks when i read the sticky.
Old Jun 18, 2009 | 07:16 PM
Maven's Avatar
There are no 276mm front rotors.
There are 256mm, which is 4lug only. There is 280mm which is the 2009 G5GT, and all 5 lug cars with drums in the back, 296mm is whats on non Brembo 4whl disc cars except the 09 GT. Then there is the Brembo 315.5s
Old Jun 19, 2009 | 10:19 AM
evZO6's Avatar
thanks looks like i will have to wait for someone to make a brake for this car.
evZO6's Avatar
evZO6's Avatar
Old Jul 1, 2009 | 01:12 AM
evZO6's Avatar
if i got a set of calipers for the 296mm rotors would they bolt up to my car so that i could do use aftermarket brakes.
Old Jul 1, 2009 | 09:03 AM
Maven's Avatar
Sure would. Thats what i did on my car. I went from four lug 256mm, to 5 lug 296mm, to 311mm Koni Challenge brakes.
Yes a 296mm (SS) Caliper and bracket will bolt right onto your car and allow you to run SS 296mm rotors, really the best way to go for the money.
Old Jul 1, 2009 | 10:42 AM
evZO6's Avatar
This is the ssna-2.4 not the ss/sc correct
Old Jul 1, 2009 | 01:00 PM
Maven's Avatar
2.4s and SCs have same exact brakes
Old Jul 1, 2009 | 02:45 PM
evZO6's Avatar
Know a good place to find the brakets and calipers. online or is this go to a junk yard and dig around for a set.
Old Jul 1, 2009 | 05:52 PM
Maven's Avatar
Online gm places, local auto part store, online auto part store, Morad or Schram auto parts on Ebay.
Old Jul 31, 2009 | 03:26 PM
stevedwg's Avatar
GM parts source online
I found that for all parts GM that www.GMPartsDirect.com has prices at about 1/2 that of dealership parts. But you have to KNOW the correct PN. No returns I believe. But they do take CC's
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
