Brake problem???
Old Dec 5, 2007 | 11:53 PM
SS BEEOTCH's Avatar
Brake problem???
Ok I noticed I was getting a vibration a lot at high speeds. Me being a tire technician I knew the tires were most likely out of balance. I had been playing around with the car, you know screeching tires and what not. Well I was really busy lately and then one day noticed i was getting REAL BAD vibrations at high speeds and even worse while braking. So I took it to my shop and balanced the wheels. I am not THAT knowledgable, but I know the basics, so I was looking around, and I noticed the right caliper had indications that something was scrapping the caliper. Nothing else had scrape marks. Also the right side was SCORCHING and the left side was not.
Took the car to the dealership and told them the problem. They said the pulsation was because the rotors were jacked so they reserfaced them. Found no other problem. I never checked for the heat, but today driving it I noticed the pulsation coming back.
Anyone know of known problems with the brakes on these?
Old Dec 6, 2007 | 04:42 PM
BigTizzle903's Avatar
idk. i got a 2.2 and my rotors warped with under 5k miles. dealer resurfaced then and they are fine now with almost 10k miles
Old Dec 6, 2007 | 07:32 PM
montecarloman's Avatar
Seems like you might have a sticking right side caliper, if its scorching the rotor and the pusation is returning this quickly.
Old Dec 6, 2007 | 07:36 PM
DebadgedBALT77's Avatar
hmm, yea if that keeps warping and what not maybe its a bent hub. and they probably used an off car brake lathe. Ask if they an use an "on car " brake lathe . that will greatly reduce the hances of a vibration from a rotor again.
Old Dec 6, 2007 | 09:07 PM
You cant really bend a hub. Lower control arms, tie rods, struts, and knuckles are bendable parts. Hubs growl or become loose when they are at the end of their lives.
Old Dec 6, 2007 | 11:19 PM
loose, etc, rust behind the rotor, thats what i was trying to get at. only running on a few hours of sleep here. sorry.
Old Dec 12, 2007 | 01:09 PM
chevy1280's Avatar
yeee
I had to take my 06 back with 600 miles to have them switch rotors out. I noticed it on right side, and it's comming back Also notice at high speeds.
Old Dec 12, 2007 | 01:18 PM
68nova200's Avatar
my parents HHR does that about every 10K miles or so they just need to be resurfaced it is very annoying.
Old Dec 12, 2007 | 03:40 PM
ever figure out what it was?
Old Dec 13, 2007 | 09:28 AM
Todd TCE's Avatar
Pad transfer problems from a combo of poorly matched compound to the use and driving habits.
Overheated compound breaking down upon the rotor surface from high temp usage. "Spirited" driving and/or freeway stop and go. Combine that with a habit of holding one's foot on the brake pedal after stopping and the pads are baking to the rotor. More common on Automatic cars where this is required but can appear on std tranny cars also. Creeping at a stop can help on Autos as well.
Solution? Pads that will operate in a higher temp range and not break down so quickly when hot and learning to not hold your foot on the brake pedal. Rotors full of holes; no. SS hoses; no. High temp brake fluid; no. Pads and diving habits.
Old Dec 19, 2007 | 02:58 PM
criton's Avatar
Mine TOOO
My New Balt, Vibrates that same way. I have 13k on it and have an appointment to get the back turned.... Annoying.
I'm actually looking into aftermarket, beefier brakes to replace the factory...
I'm just not happy with the stopping power at higher speeds.
Being in houston, and all the whacked out drivers here, stopping in a hurry is more a matter of survival then a want..
But I agree, the resurface of the brakes will get annoying if its every 10k or so...
Old Dec 19, 2007 | 03:05 PM
blissmaster13's Avatar
I had to get my rotors resurfaced 3 times before 10,000 miles. They said if it happened again they would replace the rotors, but damnit it has not come back.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
