Brakes
Old Jun 21, 2009 | 09:49 PM
Mike08ss/tc's Avatar
Brakes
Im not sure if there is a thread out there or not. I am just wondering if there is any slotted or crossed drilled rotars out there yet for the LNF's.
anybody know of any. I have looked but might have mis looked
Last edited by Mike08ss/tc; Jun 21, 2009 at 09:49 PM. Reason: Automerged Doublepost
Old Jun 21, 2009 | 09:55 PM
gatekeeper's Avatar
Not that I've seen. Of course, you realize that this would be a cosmetic only modification, right?
I just got done pounding on the stock brake system today, on some of America's most extreme roads (US-129 aka Tail of the Dragon, Foothills Parkway, Cherohala Skyway) repeatedly pulling down from high speeds -- combined with some pretty steep elevation changes. A fluid and SS line upgrade would prolly be the best bet, IMHO.
Old Jun 22, 2009 | 09:52 AM
qwikredline's Avatar
turbo balt brakes are great, but slots are not cosmetic, they help keep the pads from glazing. Brembo rotors are great too, to do better you need a floating rotor. The initial cost of the hat in a floating torot makes the first buy a lot, but after that its not too bad for replacement rotors. The stock TC rotor is a 26mm thick part, and ideally we would like to squeeze a 28mm part in there, which is do-able if you remove the anti squeek shims and maybe shave the Caliper pistons. You want a thicker rotor if you can package it as in brake cooling MASS IS EVERYTHING....but if you do all that and folks start complaining about brake squeal, well you get nothing for nothing and you gotta pay the price. My turbo brakes squeaked a lot initially but now they have shut up, I must have beaten the squeal out of them!
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
