Brakes
Brakes
Just wondering if anyone else is experiening brake grind...my brakes grind mostly when its cold..Could the rotors be warped? pads worn? its only been 6 months i dont usually break that hard...lol also car pulls pretty bad when brakes are applied... just curious to hear ppls reviews....Thanks
I haven't had any problems with grinding or pulling... but definately vibration.... go have the brakes checked at the dealer, they'll probably need to resurface your rotors.
No rust....I had the wheels off the other day to put on my winters, thanks for all your info ill be paying a visit to my dealer ASAP... Thanks Again!!
Mine grinds like crazy when it's cold and mostly when backing up, one also squeaks and squeals. Seems like the problem is mostly in the right rear. I've got a long list for my dealer to look at, and brakes are on there.
Originally Posted by hennessey833
Some people are having some trouble with the rotors getting eaten really quick because GM apperantly used too hard of a brake pad.
hard pads last longer but dont stop the car as well, soft pads wear alot faster but stop the car much better. gm most likely used soft pads. i think you got it backwords.
same problem here
both front rotors r scratched up
i was gonna bring it to the dealer a couple of days ago... but i wasnt sure if i got warrenty on it cause i put in the k&n CAI
that shouldnt void warrenty right? any1 no?
