Brembo bleeding question
I have two questions... One I have seen two different diagrams for bleeding your brakes which one is right either R/R to L/R to R/F to L/F. Or is it R/R to L/F to L/R to R/F????
Second question on the brembo cailpers when you bleed them do u open the two bleeders at the same time? Or do u open the inner bleeder first then the outer bleeder???
About to bleed my brakes tomorrow so try ing fiqure out the right way.
Ok I thought the first diagram was right. But ok anybody else know about the brembos if it's inner first then outer or the other way around?? The inner then outer makes sense but sense when do cars make sense.
Ok but with the cailpers design as I'm sure you know the brake line goes in the back.... Yeah I know obvious remark. But if you bleed the outer first then when you bleed the inner and any trapped air in the lines could be pushed back into the outer part of the cailper again. But maybe not it's just a thought I had. What is your option on that??
X split system with abs. so RR/LF/LR/RF. bleed inner first on brembo, outer last. thats my plan.
sox fan was right for cars BITD. not now. lol
ya i like the two people way also; pump'er up/down/pump;er up/down/relax lol Abs bleed requires a Tech 2 should not be needed for 99% of the time.
SHould be a a sticky or edited onto one of the FAQs.
Or someone could write a quick HOW-To for the HOW-to area.
Ok so most of the time meaning if you don't replace the abs unit? And if I had more time I would write up a how to with some pics to but trying to do it fast starting an 18 hour drive the same day I do it.
Iceberg
Sep 29, 2015 12:33 PM
