Camber plates
Camber plates
i know that no ones makes camber plates for our stock setup...mr powell said you can mod vw ground control plates to work..but i was poking around and found these and i'm wondering your guys thoughts on these on a stock setup what would be involved in getting this to work
Anyone ever tried these:
Chevrolet Cobalt B&G Pillowball Camber Plate - PB-CV-102 by B&G Suspension
I have been looking into this as well and ran across these the other day.
Camber Kits for the Chevrolet Cobalt from HorsepowerFreaks
HAHA These people have done some serious R&D for us here, camber bolts to adjust our rear camber and toe. lol
Technically, all that info is true. But it's not a good idea to shim the rear.
Besides, camber bolts work fine, and are safe. Just get those. You all want camber plates just to be ballers. If you wanna be a baller, get coilovers.
If you want camber, just get the bolts.
If you REALLY want a functional top hate, turn it sideways and control caster.
Scott
You gain camber up until the control arm is perpendicular to the strut. Which is why lowering the car too much has so many detrimental effects.
I very carefully drilled and tapped the bolt to work with my 14mm Konis and I've used both the B&G top caps and the flatter Ground Control top caps. I've recommended to other people that you get a machine shop to drill and tap to get a perfect bolt alignment.
Scott
Scott
disadvantage is no isolation. every pebble will be like going over train tracks, and train tracks will be like "omigod i crashed the car"....
agentirons
Oct 16, 2015 02:11 AM
z28addiction
Sep 28, 2015 12:03 AM
